2017 reporting 280 mile range instead of 330 miles
Discussion in '2.5 Gen Tundras (2014-2021)' started by YodaPower36, Jan 30, 2023.
  1. Jan 30, 2023 at 6:53 AM
    YodaPower36
    YodaPower36 [OP] New Member
    Ryan
    Kennett Square, PA
    2017 Tundra SR5 Double Cab
    Exterior: 3.5 rc lift Fuel Vandal 20x9 1 mm offset on 35’s, Trd dual exhaust, Spyder Industry Steps, rekgen mud flaps, Trd pro grille, Diode Dynamic SS3 fogs, YotaLED grille lights, ApexOffroad bumper shims. Interior: Heated seats, RC seat covers, Full head unit and stereo replacement. KENWOOD 1057xr, Kicker amp/sub combo,
    So I have a 2017 5.7L I force. I am getting 12.5 mpg I have a 26.4 gallon tank= 330mpg but it’s saying it’s 280 why is that when it’s full? I have 49,000 miles should be broken in by now. Could there be a sensor accuracy issue? Just curious of why it’s not accurate from the math.
  2. Jan 30, 2023 at 6:55 AM
    Taco-Spike
    Two Trucks
    It keeps a few gallons in reserve that it doesn't calculate. You can drive another 30-40 +/- miles after it says empty
    YodaPower36[OP] likes this.
  3. Jan 31, 2023 at 9:02 AM
    LiftMeUp
    LiftMeUp New Member
    I've got a 2013 with 26 gallon tank. I've run 55 miles with the light on and the most I've been able to put in the tank is right under 23 gallons. I'm only getting about 15 miles per gallon. I've read there is like a 6 gallon reserve. Heck, 50 over and still 3 gallons in the tank.
  4. Jan 31, 2023 at 9:05 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    6 gallon reserve is accurate. However, it shouldnt be used regularly as it has alot to do with keeping the fuel pump submerged in gasoline for proper function.
    nobodyintexas and LiftMeUp like this.
  5. Jan 31, 2023 at 9:06 AM
    Moe2o4
    Moe2o4 New Member
    Corey
    2020 Tundra SR5 Extended Cab TRD Offroad Package 8ft. Bed
    Bilsten 6112's with 2.5" Front Lift w/Bilstein 5160 Rear Shocks
    I've got a 2020 with a 38 Gallon tank and average around 9 MPG and after every fill up 408 comes up on the dash but usually when i put gas in it at 1/4 tank or a little above it usually takes about 30 gallons. I want to say the reserve is around 8 gallons give or take.
  6. Jan 31, 2023 at 9:28 AM
    Those numbers are just estimates. My fill ups say 409 consistently and I average 13.6 mpg.
    Moe2o4[QUOTED] likes this.
  7. Jan 31, 2023 at 9:29 AM
    Moe2o4
    Moe2o4 New Member
    Corey
    Yep just estimates. I average about 75 miles per 1/4 tank, usually a bit less.
  8. Jan 31, 2023 at 10:28 AM
    FYI....gas flow "through" the pump cools it
  9. Jan 31, 2023 at 10:35 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    It is generally accepted the tank has a 6 gallon reserve. I fill up my 26.4 gallon tank as the low fuel light comes on. Almsot every time I get high 20 to low 21 gals before the pump shuts off.
    The Toyota algorithm is an estimate at best. Calculations are done by the instrument cluster after receiving injector pulse info from the ECU, fuel level from tank sender, distance travel from ABS ecu.
    Keep in mind tire sizes will effect this also. The ABS ecu is programmed to the factory tire size. Changing tires will cause error in the distance signal reported to the cluster.
    My MPG on the cluster says I am getting about 12-12.5 mpg. Reality is closer to 11 Mpg from calculations at the pump. I have a spreadsheet and log every fill up.
    This winter time gas blend and idling more to warm the truck up took me from 13-14 mpg in summer to 11 mpg now in winter
  10. Jan 31, 2023 at 10:48 AM
    LiftMeUp
    LiftMeUp New Member
    With my light, I struggle to hit 20.5. But don't have computer generated MPG so figure on my own. 14.5 - 15, all highway miles, but at 75/80mph. But jumping up tire sizes put a hurting on miles per gallon. But gotta look good right!
  11. Jan 31, 2023 at 10:56 AM
    18" TRD Off Road Wheels
    You're getting better than you think if you haven't adjusted for the larger tires.
  12. Jan 31, 2023 at 11:05 AM
    2mchfun
    Without extra reserve, the truck would likely have problems with fuel starvation. Think steep driveway for a second or climbing a long steep grade. Would you want to be slowly crawling up or down a big muddy hillside and run out of fuel because it all ran to one end of the tank leaving the pump pickup dry?
  13. Jan 31, 2023 at 11:17 AM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    I had thought that the 2016+ 5.7L's all got the 38 gallon tank on every trim above the SR. No?
    I've never run my tank terribly low, I wonder if my 2016 SR5 has the 38 tank or not, hmm. Running the VIN on Toyota's site confirms it's go the SP SR5 package and all that but doesn't mention the tank size.
  14. Jan 31, 2023 at 12:35 PM
    LiftMeUp
    LiftMeUp New Member
    Well, I just run the numbers from what it takes to fill and miles and come up with the average. 34.5" not too fuel efficient.
  15. Jan 31, 2023 at 12:46 PM
    Right, but you have to account for the extra distance travelled per revolution of the tire. You're odometer and speedometer will be off by the same percentage that you increased the tire circumference by.
    LiftMeUp[QUOTED] likes this.
  16. Jan 31, 2023 at 12:52 PM
    LiftMeUp
    LiftMeUp New Member
    Ahh, true. Didn't think about odometer. but it's really small. I think drive to drive from home to work was only a difference of less than a mile over a 75 mile trip. But never crossed my mind!
  17. Feb 2, 2023 at 9:31 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    +1, a 34.5 is at least 6% bigger then OEM.
    GODZILLA[QUOTED] likes this.
