2017 rear differential noise
Discussion in '2.5 Gen Tundras (2014-2021)' started by Kidharvey, Sep 19, 2022.
  1. Sep 19, 2022 at 6:18 AM
    Kidharvey
    Kidharvey [OP] New Member
    Harvey
    2017 blue 1794ed
    None
    New member here, so bear with me... I have a 17 (Wife's) and 16 tundra. 17 rear diff scrapping sound --- rotor (OEM rotor) grinding against e brake back plate.... no obvious rust, diff gear oil looked fine, no play i could feel, and no grinding sound when truck is in drive on the lift.... but spin axle by hand n hear a clear gear tapping sound (poor explanation, but have video .. too big for upload)... dealer states limited slip on tundra is reason for sound.. no issue!! My issue is my 16 has 20k more miles n sound is very different! Thanks for any insight
  2. Sep 19, 2022 at 6:52 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    If your truck is stock, it doesn't have a mechanical LSD. Your auto LSD works through the braking system to mimic a true LSD. Maybe the ring and pinion/ bearings inside the diff are making noise, but it's not probably not the "limited slip" making noise.
  3. Sep 19, 2022 at 7:50 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    It could be the Pin inside the diff backing out and making contact as it rotates. As stated, the factory rear is not an LSD. That pin is the weak point of the otherwise big and strong 10.5” diff. I’ve heard a lot of 1 wheel peels can cause it to back out over time. The solution is to install a real LSD unit like a Powertrax or Auburn, or a locker like an Eaton/Harrop or ARB.
    des2mtn likes this.
  4. Sep 19, 2022 at 8:13 AM
    Kidharvey
    Harvey
    2017 blue 1794ed
    None
    Good copy... I knew not true LSD, BUT don't know details of how it mimicked LSD. Therefore, sounds like I should upgrade or check pin? Have yr or 12k left on warranty, so I was hesitant to pull.
    Thanks
  5. Sep 19, 2022 at 8:18 AM
    Kidharvey
    Harvey
    2017 blue 1794ed
    None
    Did replace rear rotors n brakes.. they were close n noise increased to turns left n right ... rotor e brake area is .03mm deeper than stock. Scrape cause n sound, which I assume was rear axle bearings going. Seems not to be case? Having that diff milled... praying sound goes away!!
