2017 bed question
Discussion in '2.5 Gen Tundras (2014-2021)' started by sonofdad, May 23, 2023.
  1. May 23, 2023 at 1:12 PM
    sonofdad
    sonofdad [OP] New Member
    steamboat springs, co
    2017 Tundra SR5
    i've searched here and elsewhere but haven't found the info i'm looking for.
    i'm wanting to mount brackets inside the bed of my tundra (2017 SR5 DC) just above the wheel wells (see pic below). these would be screwed in after drilling pilot holes:
    i'm trying to figure out how much space there is between the interior wall of the bed and the corresponding exterior panel. i can see that there's a decent sized gap back by the taillights, but can't seem to figure out how to check the area indicated above (i have a topper on my rig).
    short of going for it and drilling into the bed to find out (something i'm not eager to try) is there any way i can figure this out?
    appreciate the help, hope i explained myself clearly.
  2. May 24, 2023 at 7:46 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Remove the wheel well lining above the driver rear tire. There's a ton of space in that area.
    Sean492, sonofdad[OP] and biebs96 like this.
  3. May 24, 2023 at 9:20 PM
    Jack_A_Lope
    Jack_A_Lope New Member
    Aaron
    Santa Barbara County, CA.
    2019 Tundra 4X4 SR5 TRD Sport
    Pro Comp Lift, Tires & Wheels, Steel front bumper with LED lighting, Cross bed tool box, bed rails, custom aftermarket sound system
    Stand in the bed of the truck with your hands, one on the inside and the other on the outside. You can get a general feel for how big the space is between them. It's roughly an inch at the closest I believe.
    sonofdad[OP] likes this.
  4. May 24, 2023 at 10:13 PM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    IMG_3272.jpg Just do it!!!
    matictundra and Sean492 like this.
  5. May 24, 2023 at 10:36 PM
    SD Surfer
    Bruce
    So Cal
    You probably already know this, but just in case...
    Wrap some duct tape around your drill bit 3/8th's or so up the bit so it'll stop you once you penetrate the sheet metal. (Unless you have an actual depth stop)
    sonofdad[OP] and Tundrastruck91 like this.
  6. May 25, 2023 at 7:09 AM
    sonofdad
    2017 Tundra SR5
    i ended up doing what @Jack_A_Lope suggested to get a better idea how much space i had and then crossed my fingers and went at it with a drill. after the hole was made i poked around with a piece of wire ... plenty of space between the two walls ... probably an inch or two.
    thanks everyone for the input!
  7. May 25, 2023 at 7:57 AM
    SD Surfer
    Bruce
    So Cal
    Soooo, you just gonna' leave us hanging?
    Whatchya' mounting to the brackets? :popcorn:
  8. May 25, 2023 at 11:30 AM
    sonofdad
    2017 Tundra SR5
  9. May 25, 2023 at 12:06 PM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    Paint the holes after drilling, use stainless nylon-insert nuts and bolts instead of screws, and some big washers to help distribute the weight loads better, my advice!
  10. May 25, 2023 at 1:02 PM
    SD Surfer
    Bruce
    So Cal
    sonofdad[QUOTED][OP] likes this.
  11. May 25, 2023 at 1:13 PM
    sonofdad
    2017 Tundra SR5
