2016 Tundra TRD check enginge light
Discussion in '3rd Gen Tundras (2014+)' started by pearl, Aug 14, 2016.
  1. Aug 14, 2016 at 9:00 AM
    pearl
    pearl [OP] New Member
    2016 tundra try
    none
    I have my first tundra I have under 1500 miles and the first time check engine light came on I took it in to dealership. They checked it and they found a small leak. They put a new gas cap on. they told me that the first on was free and the next on would be $90. I asked how I could have messed up cap their answer was I put the cap on wrong. I not stupid. Everything rock on for a month or so. I don't put many miles on a truck, but the engine light came on at about a half tank full. I have not touch the cap until I filled up again. It took a couple of weeks for it to go off before so I will see if it happens again. Has anyone else had the happen?
  2. Aug 14, 2016 at 9:05 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Probably not the gas cap. Same thing happened with my 2016. They said it was the gas cap but it threw the code a day or so later. With mine, the charcoal canister was leaking which tripped the CEL. They had to order a new one and replaced it a week later. Either way, don't stress. It's just a emissions thing that has zero effect on how your truck runs. Get it to the dealer, have them check it out and fix it.
    Oh, and welcome to the forum.
  3. Aug 14, 2016 at 9:07 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Also, did you top of the tank when you filled it up? If you continue to fill up the tank after the first click, you can ruin that charcoal canister because it floods it.
    Law323 likes this.
  4. Aug 14, 2016 at 9:08 AM
    pearl
    2016 tundra try
    none
    Thanks you.
  5. Aug 14, 2016 at 9:09 AM
    pearl
    2016 tundra try
    none
    No when it click off I take it out
  6. Aug 14, 2016 at 9:42 AM
    RowdyRon
    RowdyRon SouthBoundSteve Fan Club President
    Ron
    Bentonville, AR
    2015 Radiant Red TSS Doublecab 4X4 Off Road
    Deck rail system, Bed divider, door sill protectors, LED reverse light bars, Aries Bull Bar with 28" 180 watt LED light bar, LED step lights, LED bed lights, driver-side grab handle, TRD Rear Sway Bar, BedRug bed mat and tailgate mat, Morimoto Fog Lights, more to come.....
    Plus, I don't think a dealership can pull "the first repair is free and any additional are $90). That is BS for a brand new truck still under warranty. Believe me, if a dealership refused to cover a claim under warranty for me they could either fix it before we went to court or shortly thereafter.
    Law323 likes this.
  7. Aug 14, 2016 at 9:53 AM
    pearl
    2016 tundra try
    none
    I agree. And you are so right that we are free today because of our Veteran past, present and future. God Bless you
    RowdyRon likes this.
  8. Aug 14, 2016 at 10:38 AM
    RowdyRon
    Ron
    Bentonville, AR
    Thanks, Pearl!
  9. Aug 14, 2016 at 11:17 AM
    Spvrtan
    Spvrtan Mod In Training | MIT
    Kris
    San Diego, CA
    Overland '14 CM w/ SC on 40s
    Buy a code reader so you can see what the problem is.
  10. Aug 15, 2016 at 12:52 AM
    bj46-taco-tundra
    bj46-taco-tundra New Member
    Mark
    Bj46 taco and now a tundra
    What do you mean "first click"?
    Tightening the gas cap
    Or
    The click the gas pump handle makes when it you fill up.
    Or
    Something totally different.
    Because I'm defently the fill it right up as much as it will take when I'm on a road trip. Daily it's go to the exact dollar while filling up.
  11. Aug 15, 2016 at 4:23 AM
    RowdyRon
    Ron
    Bentonville, AR
    Don't fill the tank past the 1st time the fuel pump shuts off and you won't have an issue.
    RLHOK likes this.
