2016 tundra rust spots
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Bsones, Apr 15, 2023.
  1. Apr 15, 2023 at 6:24 AM
    Bsones
    Bsones [OP] New Member
    2016 tundra
    Do any of you have pin head size rust spots coming through? I find it odd a 2016 has rust on the body already.
  2. Apr 15, 2023 at 6:25 AM
    Northern Toyota
    Northern Toyota New Member
    2023 Tundra TRD Off Road, 2025 Tacoma TRD off road premium
    Tires and bilstein
    Iron particles on the surface. Try iron x or clay bar. Common thing after winter. Have any pictures?
  3. Apr 15, 2023 at 6:40 AM
    Bsones
    2016 tundra
  4. Apr 15, 2023 at 6:46 AM
    Northern Toyota
    Tires and bilstein
    Those are iron particles that have attached to your paint from the environment. Metallic brake dust, iron from winter plow blades, rail dust. Being a white truck they are more obvious. The salt from winter turns then orange/rusty in colour. There are various iron removers out there that you spray on your paint and pressure wash off. Some chemicals require washing by hand. A clay bar will remove them as well but best to get the larger/majority of the particles off with a chemical spray first.
    that one on the bottom of the door looks like it may be a stone chip. Iron x will remove the rust a bit but you should clean it and touch it up with paint before it spreads.
  5. Apr 15, 2023 at 6:50 AM
    Bsones
    2016 tundra
    Great news, thank you. I looked up clay bar quick and I see on Amazon it comes with a lube and the bar. I'll give it a shot. I thought it was kinda early in age to have rust already
  6. Apr 15, 2023 at 8:28 AM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    You'd be better off using an iron remover like Iron-x from Carpro, maybe followed up with the clay if you want.
    https://carpro.global/catalog/ironx/
  7. Apr 15, 2023 at 9:02 AM
    Bsones
    2016 tundra
    Will do. Thanks again
  8. Apr 15, 2023 at 9:56 AM
    Northern Toyota
    Tires and bilstein
    Yes, this way you remove the bulk of the iron particles before claying
    sask3m[QUOTED] likes this.
