2016 Sequoia: Momentary Electrical Issue - Several Dash Lights
Discussion in 'Sequoia 2nd Gen (2008-2022)' started by JoJoCal19, Nov 24, 2019.
  1. Nov 24, 2019 at 4:34 PM
    JoJoCal19
    JoJoCal19 [OP] New Member
    Driving today and suddenly I received several lights on the dash come up, and was getting a BSM error in the multi-information display as well (turned that off and that msg went away. As well the speedo stopped working. Was driving fine otherwise so popped into a parking lot and shut it off and back on and it went away.
    In Googling I have seen various posts of similar lights on Tundras. Was curious if anyone had a clue what caused this. I guess if it were to happen again I'll have to see if I can get into an Autozone or something and see if they can pull a code.
  2. Nov 24, 2019 at 5:09 PM
    TheBeast The Beach
    see if it comes back. might just be a fluke.
    scan the codes if anything pops up.
  3. Dec 24, 2019 at 3:58 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    As TheBeast sez, get yourself an odb2 reader (they're cheap), there maybe a Pending code.
    Yet the power steering warning light is telling you Something. Have you checked it's fluid level, is there enough when hot? Perhaps its slightly low, enough when you incline the vehicle it sucks air and sets off the warning. Not sure if slip and center diff lights are related...
    The potential pending CEL is the clue you need to figure this out Before it grows to be a real problem. It's just giving you a warning now...let us know what you find.
    Luck and enjoy those Toyotas. : ^ ))))
