2016 leaking oil!!!!
Discussion in '2.5 Gen Tundras (2014-2021)' started by Redturbulance, Jan 22, 2017.
  1. Jan 22, 2017 at 3:33 PM
    Redturbulance
    Redturbulance [OP] New Member
    Butte,MT
    Stubby antenna, amp research steps, Line X, tinted front doors and windshield
    So this is my first post but I've had my tundra since last February.
    This is my first Toyota and i ordered it and received with 3 miles on it. I added amp research steps, Truxedo lopro qt tonneau cover and line x bed. Everything was great including a couple trips to seattle but very little driving for the most part.
    I then started having trouble since October 2016 when I came out to oil all over the ground.
    I couldn't believe it...I only had like 6k miles at this time cause I have a work Truck and barely drive the tundra.
    The dealer tells me it's the cam bucket and they would have to keep it....3 weeks goes by and I get it back. I drive it off the lot and the cel comes on. I returned it and it was just a sensor that wasn't plugged in all the way.
    A couple weeks go by and I notice oil drips in my garage cause my garage is epoxy coated.
    I take it in again and they say the valve cover is leaking cause they reused the gasket. So they take 2 weeks to get the part and fix it.
    So now I think I'm good to go and I have made no complaints and have been patient since I'm friends with the service manager. However I start noticing oil again and now coolant. I take it back and my friend yells at the mechanic and after thorough investigation they notice a loose coolant clamp as well as the original cam bucket repair is leaking on that side and now the other side is leaking as well. They say they are going to redo both sides now.
    I am now thinking WTF have I got myself into. Is this gonna kill my resale? Do I call Toyota and discuss lemon law stuff? Do I bail on this and get the 2018 asap?
    Just wondering what you guys think. Anyone else have leaks like this?
  2. Jan 22, 2017 at 3:44 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    If the dealer told me it was leaking because they re-used a gasket, I would already have been on the phone to Toyota.
    rons23, mdavis and ColoradoTJ like this.
  3. Jan 22, 2017 at 3:57 PM
    Motor71
    Motor71 teufel hunden
    Rob
    New Jersey
    2016 tundra platinum
    TRD sway bar, matching mirror cover, 20% tint, esp aluminum box, Line-X premium, Undercover Flex tonneau cover, led interior lights, winjet smoked tail lights. Road armor rear bumper w/ road armor shackles, go rhino front bumper.
    Toyota needs to take care of that!
  4. Jan 22, 2017 at 4:12 PM
    MatthewPTguy
    MatthewPTguy Not a new member
    Eugene, Oregon
    2017 Tundra 5.7 DC TRD MGM
    Borla dual cat back exhaust system, K&N replacement air filter, Headlight Revolution 40" Stealth LED light bar, Headlight Revolution LED fog light replacement bulbs, Line X bed liner, de-badge
    UGH THAT SUCKS!!! I would definitely call Toyota. I had an issue with an oil leak where the transmission meets the engine block....
    https://www.tundras.com/threads/oil-leaking-from-main-bell-housing-again.5804/
    See my thread above... although your leak is in a different place, you should still get SOMETHING from Toyota. Oregon has pretty specific qualifiers for Lemon law... but I would for sure look at Montana's laws.
  5. Jan 22, 2017 at 4:26 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    3 times and over 5 weeks. I think that would qualify for the lemon law in CA. I would check with your state laws. Search lemon law lawyers, I believe some work for free, they'll collect from the settlement from Toyota. Wouldn't be a bad idea to talk to one before you talk to Toyota to see if you have any leverage. Good luck OP.
  6. Jan 22, 2017 at 4:54 PM
    Lowcountrytj
    Lowcountrytj Buford T. Justice
    Phillip
    SE GA
    2008 Tundra DC, SC
    Yep what they said....
    Welcome from GA by the way!
    Hopefully they will get you squared away quickly.
    Great looking truck also.
  7. Jan 22, 2017 at 5:32 PM
    trainracer
    trainracer New Member
    sounds like the service department has some issues time to find a different dealer
  8. Jan 22, 2017 at 5:41 PM
    Dealership hiring bad ASE certified mechanics probably just young kids right outta mechanic school with no real time on under there belt just doing the job quickly and not taking time do to right I'd be yelling at dealership manager and service manager
    NewImprovedRon likes this.
  9. Jan 22, 2017 at 5:42 PM
    Or also someone asleep or not doing ther job right at Toyota assembly line plant
  10. Jan 22, 2017 at 5:47 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Bummer. You initially had a leak which sucks to begin with but was compounded by a bad service tech. I really don't think lemon law would apply here but you should def be talking to Toyota and the service manager, not just your friend. They need to compensate you in some way for your inconvenience like free window tint, free extension to the mileage services, extended warranty or something.
  11. Jan 22, 2017 at 5:48 PM
    LML 3500HD
    I agree with you guys, but it isn't so easy in Montana. His next closest dealership is a bit away from Butte.
    2cID likes this.
  12. Jan 22, 2017 at 5:52 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Looks like Montanas law is Similar to CA law.
    • Be under 2 years old and have fewer than 18,000 miles on the odometer.
    • Have undergone at least 3 attempts at repair by the manufacturer.
    • Be out of service due to the defect for a total of 30 business days or more during the warranty period.
    ColoradoTJ likes this.
  13. Jan 22, 2017 at 6:01 PM
    LML 3500HD
    That sounds about right. I worked for Toyota when I lived in Montana. We didn't have a lot of lemon law issues, but the service manager would be all about the customer if it was returned even once.
  14. Jan 22, 2017 at 6:06 PM
    Redturbulance
    Butte,MT
    Thanks for all the input. The closest dealer is 65 miles up in Helena.
    Never thought about compensation in requesting a extended warranty.
    The situation is difficult because it's a small town and everyone knows each other and my wife and I are friends with the service manager. They where already aggravated I bought the truck in denver after giving them a chance at my business. There was no comparison in price though.
    I'm gonna call Toyota about it and I'll just let my friend know about my plan 1st.
  15. Jan 22, 2017 at 6:21 PM
    Clover-01
    Clover-01 Make them tell you "Hell No"
    Jack
    San Antonio Tx
    2014 Silver CM 4X4 Platinum Tundra, 2012 Silver Dbl Cab 4X4 SR5 Taco (For Sale)
    Stock for now!!!
    I don't think it will hurt resale but if someone does their homework and search service records you may have to explain. It would have been hard for me to keep my cool. All that work you explained was warranted work and I can tell you that their service book does not call for reusing gaskets so they are billing Toyota for new parts then not using them. HUGE red flag here. Ask your friend to see itemized list of parts and labor for all your repairs. Sorry you had to deal with this crap.
  16. Jan 22, 2017 at 6:43 PM
    For peace of mind, ask for an lifetime warranty.
  17. Jan 22, 2017 at 7:20 PM
    MatthewPTguy
    Eugene, Oregon
    I called Toyota abouut my leak... they gave me a 7 year, 100,000 mile platinum warranty that covers WAY more than just drive train... good luck! I know how you feel...
  18. Jan 22, 2017 at 9:38 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Sorry to hear about your plight.
  19. Jan 23, 2017 at 5:03 AM
    duerj70
    duerj70 New Member
    2017 Tundra 1794 Super White
    Good luck I had a 16 that had electrical issues, traded for 17.
  20. Jan 23, 2017 at 6:54 AM
    robie56
    robie56 New Member
    Steven
    New Hampshire
    2011 white cm rock warrior
    mbrp exhaust, afe dropin filter, stubby antenna, Readylift leveling kit, ICI magnum RT sidesteps, weather techs front & rear
    I had the same issue with my 011,leaking cam towers on the drivers side. Mine wasn't leaking as badly as yours is,it would spot on the garage floor.The dealership where I bought the truck (Fenton Toyota Keene NH) ordered the parts needed, they had the truck for 3 weeks and replaced both sides.So far I haven't had any issues with the cam towers since the repair, and it has been over a year since it was fixed. I would be very concerned if my truck was leaking as much oil as yours is. I hope you are able to find someone able to repair your truck properly,it can be done.My truck had 30,000 miles on it at the time.
  21. Jan 23, 2017 at 6:55 AM
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    So I don't think this is lemon law. Lemon applies to a failure that can't be fixed by the dealer which relates to a manufacturer issue. You had 1 issue that should have been easily fixed. Toyota has had FIPG issues before. The problem you have here is shitty workmanship from the dealer. I am not sure if this would technically classify as lemon law, but there should be a law in which if the vehicles goes back for multiple attempts from the dealer or has sat for a specific number of days, they can buy it back.
    My advice: have the dealer contact their Field Technical Specialist(FTS). This is a Toyota rep responsible for technical issues at the dealer. He should be able to be involved and make sure an actual Toyota certified tech get out on your truck to fix it. This is a prime example of just bad work from the dealer.
  22. Jan 23, 2017 at 5:01 PM
    TRD Pro Rookie
    TRD Pro Rookie New Member
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    I agree with whoever said to ask for a free lifetime warranty. And get a lawyer.
    HUTCHJ likes this.
  23. Jan 23, 2017 at 7:20 PM
    Trying to sue Toyota u might as well be flushing ur money down the toilet. Just be reasonable..if u come in like an ass, be prepared for less cooperation. Attitude can go a long way- imo.
    Krezz, SouthBoundSteve, 2cID and 2 others like this.
  24. Jan 23, 2017 at 10:04 PM
    Abrams65
    Abrams65 New Member
    Cliff
    WV
    16 Tundra MGM SR5 CM OR/15 Corolla S
    ICI Magnum RT Steps, 18' LED Foglights
    I think you have been misinformed about the failure that can't be fixed thing. It is actually three repair attempts
    This is taken from the Montana Lemon Law stipulations taken from here
    Lemon Law Process
    1. Notify the manufacturer. If the problem is a substantial defect or condition that recurs or still exists after the third repair attempt, notify the manufacturer by certified mail, return receipt requested, of the need to repair the defect or condition on the fourth attempt. This notification procedure is not required under the Lemon Law, but does serve as notice to the manufacturer of your intentions.
    2. If the manufacturer fails to correct any substantial defect or condition following your written notification, the manufacturer must either refund the full purchase price – plus any reasonable expenses directly incurred because of the vehicle’s condition – or provide an identical or reasonably similar replacement vehicle. If the vehicle is bought back, the manufacturer can deduct an amount for the use of the vehicle calculated based on the odometer reading at the time of repurchase.
    3. If you think you are entitled to a refund or replacement and the manufacturer is unwilling to provide either remedy, you must first submit your dispute to a state-certified dispute settlement program approved by the Montana Department of Justice. Contact the Office of Consumer Protection for further assistance
    joonbug and ColoradoTJ like this.
  25. Jan 23, 2017 at 11:44 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Hope they get it done right and quickly and hope your truck will be problem free with no worries for the rest of your ownership.
  26. Feb 24, 2017 at 7:09 AM
    Redturbulance
    Butte,MT
    UPDATE,
    Well I called Toyota as suggested and after a couple weeks I heard back from them and they offered a 7 year 100k warranty. The truck was fixed properly by the dealer and I haven't had any further leaks at this point. Toyota was good about offering the warranty. I never got angry and just discussed the issues I was having and the concerns about the vehicles reliability.
    Thanks for all the info and suggestions.
  27. Feb 24, 2017 at 8:42 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Nice.
    I had a 2015 Silverado. At 6200 miles I started having issues w it. I got towed in 5 times within about 300 miles. Every time they had it they'd change a part that the computer told them to. Next day or two I was back on a tow truck. Finally turned out to be low pressure fuel pump came apart. With the active fuel management thing there's 3 pumps.
    They finally bought it back under lemon law. Was always a Chevy guy, never again.
    I'm glad it got me into the tundra.
  28. Feb 24, 2017 at 8:46 AM
    bigoltater
    bigoltater New Member
    KC
    2005 Tundra DblCab4x4
    Leveling Kit,33'BFG
    My neighbors brand new 2017 chevy 2500 Duramax started leaking oil after only having it a week. Chevy fixed it, just goes to show can't be 100% perfect everytime.
  29. Feb 24, 2017 at 10:46 AM
    LML 3500HD
    Great news!
  30. Feb 25, 2017 at 3:24 AM
    Berettafan
    Berettafan New Member
    2017 CM
    That is a good reasonable deal by Toyota. Nice to hear. I assume dealer gave you a tundra to drive while yours was in the shop?
