2015 upgrade to power folding mirrors
Discussion in '2.5 Gen Tundras (2014-2021)' started by darm31645, Mar 17, 2021.
  1. Mar 17, 2021 at 1:55 PM
    darm31645
    darm31645 [OP] New Member
    david
    what after market power folding mirrors will work ? I know some added wiring is required. my mirrors have heated function, power adjustment, and that is it. if the new mirror has other functions like BSM,or memory, will it work?
  2. Mar 17, 2021 at 2:14 PM
    RyeHog
    RyeHog New Member
    2014 MGM Sr5 Tundra
    I’m commenting because I would love to do the same thing. I have to fold 1 mirror to fit it in my garage!
  3. Jul 16, 2021 at 7:24 AM
    cochese
    cochese New Member
    Oregon
    '21 Lunar Rock TRD Pro Double Cab
    Bumping this thread, I'm in the same boat as @RyeHog. I've gotten used to folding the driver side mirror before entering garage, but I'd love to hit a button instead.
  4. Jul 16, 2021 at 7:59 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    RainMan_PNW likes this.
  5. Jul 16, 2021 at 8:58 AM
    cochese
    cochese New Member
    Oregon
    Well, the search function turned up a bunch of threads with replies that said "use the search function". Thanks for pinpointing a very relevant and helpful thread.
  6. Jul 16, 2021 at 9:13 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    In a nut shell:
    Memory functions are controlled by ECUs in the door. So no, memory won’t work unless your truck has memory
    If the mirrors you buy have any of the following, then:
    Puddle Lamps will only work if you already have them, or if you add wiring
    BSM will only work if you already have them, or if you add the parts and the wiring like I did
    EC/auto-dim on the side mirrors will only work if you already have it, or if you add wiring
    Power fold will only work if you already have it, unless you add the wiring and a new switch (you must use the switch from the Gen 2 Limited non-memory Tundra)
    Turn signals will work because all of the trucks are pre-wired for them (except maybe the SR trim)
    Marker lights will work because all of the trucks are pre-wired for them (except maybe the SR trim)
    Defrost will work because all of the trucks are pre-wires for them (except maybe the SR trim)
  7. Jul 16, 2021 at 9:45 AM
    cochese
    cochese New Member
    Oregon
    @RainMan_PNW comes through.
    Don’t need anything fancy, just power fold, turn signals and heat. Sounds like I’d be adding a new switch panel and some wiring, along with the new motorized mirrors.
    What am I losing with no memory? I believe that would be my situation on the Pro.
  8. Jul 16, 2021 at 10:38 AM
    RainMan_PNW
    Casey
    Clark County, WA
    With your Pro, you won’t be losing anything. The Platinum and 1794 trims have memory that saves the position of the seat, steering wheel, and side mirrors for three different drivers. For everyone else, that’s not even an option.
  9. Jul 16, 2021 at 10:53 AM
    cochese
    cochese New Member
    Oregon
    Gotcha...mirror position. Nope don't need that. Thanks :thumbsup:
    RainMan_PNW[QUOTED] likes this.
  10. Jul 16, 2021 at 10:55 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Yeah. I just use it as an excuse to not let anyone else drive my truck.
    Daughter: Dad, can I drive your truck?
    Me: No, you’ll screw up my seat and mirror settings.
    Daughter: :oops:
    Speydragon likes this.
