2015 SR5 - Leveling Kit
Discussion in 'Suspension' started by 53flattie, May 8, 2015.
  1. May 8, 2015 at 8:12 PM
    53flattie
    53flattie [OP] New Member
    Upstate SC
    2015 SR5 CM 4WD
    2.5" / 1.5" leveling kit ; 275/70/18 BFG AT/KO's
    I have "ordered" a 2015 from my local dealer that should be arriving in the next few days. I'm going to have a leveling kit installed as soon as the truck comes in, along with new tires. I bought the Tundra for towing a camper, so I don't want to go crazy with the height of the leveling kit... I inquired about a 2" front / 1" rear and the dealership said they generally install a 3" front / 1" rear along with 275 / 70 / 18's. Does this sound right? I want to be sure it's proportional - not too much empty fenderwell, but not look like the tire is squeezed in....
    Even better - does anyone have this set up and care to share a picture?
  2. May 8, 2015 at 8:30 PM
    Adkins2012
    Adkins2012 New Member
    Cody
    2014 tundra double cab sr5
    My 2014 with rough country 3 in the front and 1.5 in the back 20x9 anthem enforcers and 35x12.50 federal couragia m/t
  3. May 8, 2015 at 8:34 PM
    Welcome! Some brands to consider:
    ReadyLift
    Toytec
    With the leveling kit, you can go larger than 275/70/18 if you wanted, and probably with minor trimming.
    TNTundra08 and pmedic048 like this.
  4. May 9, 2015 at 2:59 AM
    pmedic048
    pmedic048 Pull away from the herd, drive a Tundra!
    SC
    2008 SR5 Dbl Cad, 2015 SR5 CrewMax 4x4 and 2016 TRD Limited 4x4
    3" front spacer lift and 2" rear spring lift. 20" Fuel rims with BF Goodrich G2 33.5s and Volant cold air intake.
    Good luck with your new Tundra, I did a 3" front and a rear add a leaf which raised it about 1 3/4". The reason I went with a spring instead of a block because I tow a in closed car hauler trailer. With my last truck I did the blocks and the back end of the truck would drop quite a bit. With the spring I have hardly any sag and it increases haul capacity also. I put 295/70/18 nitto terra grappler m2's on20150320_100230.jpg 20150321_095836.jpg
  5. May 9, 2015 at 11:47 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Bilstein front and rear. Front set to 2.5" and no lift in the back. Ride is much improved over stock, rides and drive like a truck now instead of a car.
    pmedic048 likes this.
  6. May 9, 2015 at 6:00 PM
    chphilo
    chphilo Tundra addict
    Western PA
    I didn't feel comfortable going with lift blocks (which I found out is illegal in PA) especially seeing some pictures of broken front struts. I went with the OME kit. I have 614 coils in the front and add-a-leaf in the rear. The front is lifted 3 & 1/2 inches and rear is lifted 1 & 3/8. Right now, the rear is 1/8 of an inch higher than the front. The ride is firm in a good way.
  7. May 9, 2015 at 7:54 PM
    53flattie
    Upstate SC
    2015 SR5 CM 4WD
    Thanks so much for the responses and pictures. They have really helped. I think I am going to go with a 2" spacer in the front and nothing in the rear. Sounds like most everyone else is going with a net difference of 2" between front and rear. With the towing I plan to do, I don't really want a block in the rear...
    Thanks again!
  8. May 9, 2015 at 9:55 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  9. May 9, 2015 at 10:01 PM
    csuviper
    Broomfield, CO
  10. May 11, 2015 at 8:30 PM
    53flattie
    Upstate SC
    2015 SR5 CM 4WD
    Thanks for all the info
    I picked the truck up today and I'm really impressed with it so far.
    In looking at the wheel wells, I'm starting to wonder if the 2.5" front spacer is even necessary.... Does anyone know if a 275/70/18 will fit without any lift? It looks like it will, but I would hate to have them installed and find out they rub somewhere.
    I actually have the 2.5" spacers and an appointment to have it installed tomorrow. But I used a floor jack to raise the front of the truck by 2.5" and it looks like it would almost have a little bit of a "reverse rake".
    I'm really laboring over this... I would HATE to pay the $400 install charge only to find out I didn't like the looks of it. Ugh.
  11. May 11, 2015 at 8:40 PM
    ^^^ Check the link in my sig...I think that's discussed in there.
  12. May 12, 2015 at 4:30 AM
    53flattie
    Upstate SC
    2015 SR5 CM 4WD
    Thanks Sean. I looked at that thread. Tons of good information, and I bet it took csuviper a looooong time to put all that together.
    The only problem is, I didn't see any information for 3rd Gen Tundras?
  13. May 12, 2015 at 5:07 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    Same as 2nd gen.
  14. May 12, 2015 at 5:10 AM
    Yep.
  15. May 13, 2015 at 4:15 AM
    53flattie
    Upstate SC
    2015 SR5 CM 4WD
    In case it helps anyone else, here is what a 2015 looks like with a 2.5 spacer in the front and nothing in the back. 275/70/18 BF Goodrich AT KO (the old tread pattern).
    a37a72d298ec87b5606794b42cf0467a_bd9fb739002ed64fecb0087ed732194ea4b93fd0.jpgd4f60bd1abf002d89e1d0e378ca6fa4b_2576bf8c8023f12a772f3b97caa268bd62c8115c.jpg
    pmedic048 and UPSed like this.
  16. May 13, 2015 at 4:43 AM
    Tugs Tundra
    Tugs Tundra New Member
    Robby
    Thibodaux Louisiana
    2014 Tundra CrewMax 4x4
    XD Series 20" wheels, Nerf Bars, Lund Revited fender flares 2 1/2" leveling kit, 285/55/r20 all terrain tires
    11242562_895666013810070_8150829611910053328_n.jpg 2 1/2" rough country leveling kit with nitto 295/65/r20 on XD series
  17. May 13, 2015 at 9:59 AM
    RoVASr5
    RoVASr5 New Member
    Daniel
    Lynchburg, VA
    '14 Tundra CM MGM
    Gibson Metal Mulisha Exhaust BDS Suspension Lift - 7 Inch Icon Dynamic 2.5 coilover reservoirs 18 "Moto Metal 18x9 +18 37x12.5R18 Federal Couragia MTs DV8 Front Bumper
    11203124_10153313543481983_6669530687282495828_n.jpg Rough Country 3 inch Front / 2 inch rear level lift. Getting 285/75/R18 Nitto Terra Grappler G2s next month for my stock wheels.
  18. May 13, 2015 at 10:27 AM
    53flattie
    Upstate SC
    2015 SR5 CM 4WD
    Update... With just the 2.5" spacer in the front, the nose was about 1/4" higher than the back. So this morning I added a 1.5" block in the back.
    Here are some updated pictures. It looks much more proportional now, with just a slight rake to it. Only bad thing is that I don't think it'll fit in the garage if I install my roof rack. Dang it.
    db6c2b69134001eb22ce4820e8ec3593_ea2940f22a2a5b360e032caf80f5b9915793a0a9.jpg5f0fffc5987032061a469eb7ce00d3cc_96567ab212dcff74f2d684def74b3c817a0714e4.jpg3325b652027ee20e8a211630a111ac9e_144a85729382d46dbe7b83052bba157727698328.jpg52e7f6b913382f05db5d7ec1307e7cfc_ca9cb4301d41e41a7b52d4a548d853407a71e8c9.jpg
    pmedic048 and RoVASr5 like this.
  19. May 24, 2015 at 4:53 PM
    TundraGU
    TundraGU New Member
    2014 Tundra Limited
    wheels/Tires Sound system upgrades
    Hello this is what I did. Wernt with a 3/2 leveling kit just didn't want it looking too high. Slapped on Toyo open country MT's 33x12.50 On 20" Xd Rockstar II's. The ride hieghts is perfect for me and love the stance I got. Huge difference from stock. The last pic is stock rims and tires plasti dipped.
    pmedic048 and 14burrito like this.
  20. Jun 10, 2015 at 9:23 AM
    RoVASr5
    RoVASr5 New Member
    Daniel
    Lynchburg, VA
    '14 Tundra CM MGM
    pmedic048 you plan on installing fender flares or no? I just installed my Moto Metal 18x9 with +18 offset and 285/75/18 tires.
  21. Jun 10, 2015 at 12:22 PM
    pmedic048
    SC
    Being the wheels stuck out about 1/2 - 3/4 of inch I was going to but after going off road and seeing that it wasn't kicking up mud on the side of the truck I decided not to put flares on.
    RoVASr5[QUOTED] likes this.
  22. Aug 13, 2015 at 10:41 AM
    Machodiver
    Machodiver New Member
    James
    2015 Black SR5 Tundra CrewMax
    What was the brand you used for this leveling setup? I am really interested in it for my truck. Seems that this kit would be stout.
  23. May 7, 2019 at 7:38 PM
    xodius
    xodius New Member
    Mark
    Vegas baby...yeah!
    2015 Tundra Crewmax SR5
    None yet but side steps this Friday who knows what’s next...
    I can hardly wait to do this to my truck. Not sure which setup just yet. Have always used OME and I love them but maybe something different this time...maybe.
