2014 Tundra USB Port Nopt working ?
Discussion in '2.5 Gen Tundras (2014-2021)' started by 2003 roadking, Apr 5, 2017.
  1. Apr 5, 2017 at 4:15 PM
    2003 roadking
    2003 roadking [OP] New Member
    randy
    2014 Toyota Tundra
    noe
    My USB Port stopped working the other day, The cigarette Lighter still works and its basically right beside it , any ideas ? is there a specific fuse for the USB port ?
    Thanks for your help
    this is my 4th Tundra !
  2. Apr 5, 2017 at 4:24 PM
    LML 3500HD
    Welcome to the site.
    USB port may be shot and needs replaced. Others on here might be able to tell you more.
  3. Apr 5, 2017 at 4:26 PM
    2003 roadking
    randy
    2014 Toyota Tundra
    noe
    Kinda Figured that, Thanks, but is there a separate fuse for that USB Port. I only have 1
  4. Apr 23, 2017 at 3:22 AM
    MT Madman
    MT Madman Just an ordinary guy
    Hawk Point MO
    2020 Silver Platinum
    TRD dual exhaust TRD Rear Sway Bar SnugTop Hi-Liner
    If there is a fuse it's probably internal to the radio head, so first question is does everything in the head work?
  5. Nov 6, 2018 at 9:57 AM
    estrare
    estrare New Member
    Reed
    2014 Tundra
    Mine stopped working too. I just replaced it and its still not working. The AUX works fine. Any suggestions?
  6. Jul 10, 2019 at 7:28 PM
    yoshi82
    yoshi82 New Member
    DAVID
    HOUSTON
    2014 Silver Tundra SR5
    3in ToYtech lift on Tundra and 2.5in in the rear. Tow Mirrors. Toyota grill, and Front bumber. New 6in antenna. Repainted the stepping boards
    i have the same problem also, has anyone figure it out???
  7. Jul 11, 2019 at 12:00 PM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    If it’s the
    If you’re using a USB cord for your cell phone, there were many times I couldn’t use it for the audio and my phone wouldn’t charge. It was a bad cord. I’ve gone through about six USB cords over the past couple of years.
    Also if you having trouble with USB connecting your cell phone to the audio and charging, clean the port of your cell phone with a very small Q-tip and rubbing alcohol. Or use a little piece of cotton on a toothpick to clean the cellphone port. They also sell cleaning sticks on Amazon. This worked for me cause us guys put them in our pockets and lint and dirt get in the port.
