2014 Tundra Radio Wiring Diagram Non-JBL
Discussion in 'Audio & Video' started by bsavoir, Nov 20, 2018.
  1. Nov 20, 2018 at 9:11 AM
    bsavoir
    bsavoir [OP] New Member
    Fort Hood, TX
    2014 Tundra SR5 DC 4x4
    Gibson Metal Mulisha Exhaust, Replaced bulbs w/ LED's, AFe intake, Bullydog Tuner, Aftermarket Audio system, Rhino Bed Light sports bar, Tonneau Cover, Spyder Auto Headlights and Taillights, Recon 3rd Brake Light, Kensun HID's, Fender Flares, Custom Leather Interior, Heated Seats, 5% Tint on the Rear Windows, Pod light Foglights, 31" light bar behind the grille, linex spray bedliner, linex sprayed grille, ditch lights w/ dual 3in LED pods, 60" Tailgate LED strip.
    I am looking for headunit wiring diagram for the connectors behind the radio. I need to rewire few things. I found some on Google but not what I need. I used to have them but lost the files I got off the TIS website a few years ago. I need the pin numbers and color of the wires.
  2. Nov 25, 2018 at 12:07 PM
    bsavoir
    Fort Hood, TX
    Got a 2-day subscription for Toyota TIS today, my new unit will be here Wednesday. So trying to get all the connectors in order to reconnect everything. Attached is what i was needing.
    Does anyone have a back side picture of the Stock Non JBL Headunit looking straight at it or what connectors come from the harness?
  3. Nov 25, 2018 at 6:41 PM
    bsavoir
    Fort Hood, TX
    After looking over all the terminals i noticed that on the J139 connector it does not have all the slots filled based on the excerpt i found. Does anyone know if all the slots are filled with wires or not. I wish i would have took more pictures of the wiring harness itself prior to my destruction of the old connectors due to impatients, at the time i didn't care and know i do. If anyone has any pictures from an old install that would be helpful anything that shows the wiring harnesses that connect to the back of the radio.
    I think I found all of the connectors im missing and currently working on fixing them but want to make sure before i install the new unit. Sorry for questions, google doesnt show very many pictures or videos of the harness close enough to see.
  4. Dec 23, 2018 at 4:53 PM
    N3skridge
    N3skridge New Member
    Nick
    Maryland
    2015 Tundra SR5 Faux Pro
    Bilstein 6112s and 5160’s SPC Upper Control Arms Coach Builder 3’ Shackle Dirty Deeds TRD/CB Steering Kit Deaver K37 with SumoSprings bumpstop swap 35x12.5x18 Fuel Rippers on Nittos Cab-Mount Chop and Bumper Shims aFe Magnum Force Intake BullyDog Tune* TRD Dual Exhaust Spyder Industries Headache Rack GTR Lighting LED swap ALL lights Headlight Revolution Hidden light-bar Total Chaos Bed-Channel Stiffeners Amp Research Bed Step TRD front and rear Sway bars TRD Blacked-out emblems TRD Grille and Hood Bulge swap Rocky Road Outfitters Kicker Sliders ARB On-Board air setup Taco Tunes/Custom Audio Rear bench seat dual Sub-enclosure LockerDown truck safe Ballistic Impressions Shift knob Mammoth Guards: Front and Rear
    Is this what you need or do you need it with all the factory harnesses still plugged into it??
  5. Dec 24, 2018 at 8:30 PM
    bsavoir
    Fort Hood, TX
    Might be a little too late, but all the wires connected if you still can.
  6. Dec 25, 2018 at 6:30 AM
    NewImprovedRon
    NewImprovedRon SouthBoundSteve Fan Club President
    Ron
    Bentonville, AR
    2015 Radiant Red TSS Doublecab 4X4 Off Road
    Deck rail system, Bed divider, door sill protectors, LED reverse light bars, Aries Bull Bar with 28" 180 watt LED light bar, LED step lights, LED bed lights, driver-side grab handle, TRD Rear Sway Bar, BedRug bed mat and tailgate mat, Morimoto Fog Lights, more to come.....
    See if this link will work for you. It is the electrical diagram for a 2015 but may work for your 2014:
    https://1drv.ms/b/s!AtFJ5ZL2i2OqlUQ6xtI0V8gd7pRS
  7. Dec 25, 2018 at 7:21 AM
    Stillkicking
    Stillkicking New Member
    David
    2015 SR double
    Audio starts page 1210... good luck
