2014 Tundra 1794 Sunroof Not Working
Discussion in '2.5 Gen Tundras (2014-2021)' started by SullyTundra4x4, Feb 4, 2026.
  1. Feb 4, 2026 at 9:32 AM
    SullyTundra4x4
    SullyTundra4x4 [OP] New Member
    I recently purchased a 2014 tundra 1794 and the sunroof doesn’t work.
    The fuse is fine, and I tried pressing down and holding the buttons and wiggling them around. I don’t hear any sounds or movement when I do this.
    Does anyone have troubleshooting suggestions for me? The more detailed the better.
    Thanks in advance!
  2. Feb 4, 2026 at 10:03 AM
    gizardlizard
    gizardlizard New Member
    Madison,WI
    2017 TRD pro Tundra
    6” lift, 35 inch tires, chrome delete, ridiculous stereo
    Do you have a scan tool with bi directional control?
  3. Feb 4, 2026 at 10:45 AM
    SullyTundra4x4
    Unfortunately I do not, I see where you’re doing with this though
  4. Feb 4, 2026 at 11:41 AM
    gizardlizard
    Madison,WI
    2017 TRD pro Tundra
    They are great for stuff like this. Might be worth the investment if you wrench at all. I couldn’t live without one.
  5. Feb 9, 2026 at 6:39 AM
    SullyTundra4x4
    I had a friend use his scanner on mine, it’s 100% the motor. I disassembled the motor housing itself and everything seems to be working other than the actual motor.
    Does anyone know where I can just buy the motor rather than the motor and the whole housing? It’s kinda pricey
  6. Feb 9, 2026 at 6:41 AM
    Local JY?
  7. Feb 9, 2026 at 7:13 AM
    gizardlizard
    Madison,WI
    2017 TRD pro Tundra
    Can you pull the motor apart for examination? My experience with sunroofs and even like power rear windows on Sequoias, is the motor gets sticky if not used regularly. If you can’t disassemble the motor, try gently wrapping on it with the back of a hard handle screwdriver while someone keeps jogging the power. It might unstick itself. If it does, put it back together and use it frequently.
