2014-2021 Front/Rear Anytime Camera Mod - FRAC Harness
Discussion in 'Audio & Video' started by TundraTex, Jun 1, 2017.
  1. May 23, 2020 at 10:33 AM
    #1351
    TundraTex
    TundraTex [OP] FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    One note I would add on the camera... It looks like this is a reverse camera only. So if you install it in the front grill, the video will be a mirror-image. Some cameras will do both functions but it doesn't look like this one will.
    831Tun and rmvcard0303[QUOTED] like this.
  2. May 23, 2020 at 10:40 AM
    #1352
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Thanks Lou. I’m seeing that in the Amazon Q&A now too.
    Do you have a recommended camera that works well with an 18 sr5 grill?
  3. May 23, 2020 at 10:51 AM
    #1353
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    rmvcard0303 likes this.
  4. May 24, 2020 at 2:42 PM
    #1354
    rmvcard0303
    rmvcard0303 New Member
    Ray
    San Gabriel Valley, CA
    2019 White Tundra TRD Sport CM
    I’d rather not list. My wife might see it.
    No worries! Its a win-win situation for everyone.
  5. May 24, 2020 at 2:43 PM
    #1355
    rmvcard0303
    Ray
    @mountainpete sorry that the camera we have isn’t ideal for your application. Let me know if still interested.
  6. May 24, 2020 at 2:48 PM
    #1356
    mountainpete
    Yes, still interested in the harness.
  7. May 24, 2020 at 3:59 PM
    #1357
    rmvcard0303
    Ray
    Ok. Will keep you posted on the shipping
  8. May 29, 2020 at 8:39 AM
    #1358
    Sh5rw9nd
    Sh5rw9nd New Member
    Southern Maryland
    2016 CM Platinum MGM
    4" ReadyLift Kit 35x12.5r20
    I have a 2016 Platinum with a PRO grill. I want to purchase this FRAC system but I do not know how to pic a camera to work. Can anyone suggest a camera that will work great with the mod and grill. I don’t mind spending a little money for quality and simplicity.
    Thanks
  9. May 30, 2020 at 8:15 PM
    #1359
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    You can check out the product links at the bottom of this thread window. Most guys are buying the Natika Front/Rear Cam. $30, durable, good picture, warranty.
  10. May 31, 2020 at 2:25 PM
    #1360
    KERNEL_DALE
    KERNEL_DALE New Member
    Norcal
    19’TRD-PRO
    Just want to share how i mounted my FRAC on my ‘19 trd pro grill.
  11. May 31, 2020 at 5:15 PM
    #1361
    mountainpete
    I’m a bit more limited on the cameras that are available in Canada, but I have this one on order.
    https://www.amazon.ca/PARKVISION-Universal-180°Wide-Multiview-Standard/dp/B07K2PKT8L
    I really wanted to find one that will show as low down in front of the truck as possible for off-road and parking.
    Cost me about $42 USD. Will report back in a few weeks once I receive and get a chance to install.
  12. Jun 3, 2020 at 4:11 PM
    #1362
    Lossy87
    Lossy87 New Member
    Carlos
    2014 Tundra Crewmax
    Where did you get that dark head unit
  13. Jun 3, 2020 at 4:18 PM
    #1363
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    that’s the stock jbl.
  14. Jun 3, 2020 at 4:37 PM
    #1364
    Sh5rw9nd
    Sh5rw9nd New Member
    Southern Maryland
    Where did you get the camera? I have the PRO grill and need the info for the camera so that I can purchase everything for the install. The one suggested was sold out.
    Thanks
  15. Jun 4, 2020 at 11:44 AM
    #1365
    Tchase
    Tchase MostlyLurk
    Buckley WA
    2019 White Tundra Limited
    In work
    @TundraTex
    Doing a dry run on my Frac harness I purchased this camera https://www.amazon.com/gp/product/B07JCSYPPS/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1
    Basically it comes with a trigger wire that it says to run to the car. My question is do I ignore the trigger switch when using the Frac harness? I've watched you video and you make no mention of it this is the same brand camera just different.
    I'm assuming I just hook it up per the video and cap off the trigger line?
  16. Jun 4, 2020 at 11:49 AM
    #1366
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    Forgot to add the pic
  17. Jun 4, 2020 at 12:07 PM
    #1367
    sunnysideTRD
    sunnysideTRD New Member
    Sunny
    2019 Tundra TRD Pro Voodoo Blue
    Standard 2019 TRD Pro but will be a project car and add as I go
    I've been trying to figure out where to mount a camera and its my next mod. Thanks for posting this.
    KERNEL_DALE[QUOTED] likes this.
  18. Jun 4, 2020 at 12:14 PM
    #1368
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    This is where I’m trying mine on my progrill
    zip ties but it’s not moving at all.
  19. Jun 4, 2020 at 12:26 PM
    #1369
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    I don't have personal experience with this version of the Natika camera, but based on the diagram, I would connect the red trigger wire on connector "C" to the trigger wire on connector "D". Then connect the trigger wire on connector "B" to the FRAC Harness red power wire. Then connect the black ground wire of the camera power cable to chassis ground somewhere in the engine bay and cap off the red wire on the camera power cable.
    To confirm this is the right approach, before you make any connections, use a meter to check continuity between the "C" trigger wire and the red power cable wire. They are likely internally spliced inside connector "C".
    Let me know how this works out.
    Lou
  20. Jun 4, 2020 at 9:20 PM
    #1370
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    You were spot on wired it just like you said. It was kind of nice one less wire to fish through.
    Another successful satisfied Frac harness installation! Thank you Lou!
    So how the install went and some suggestions?
    1. The YouTube video is great it’s all you need. If you haven’t already had experience pulling apart the interior there are plenty how to’s on YouTube. This isn’t my first mod so the interiors is a breeze. And yes going the passenger side is 1000 times easier than the drivers side. I had to go through the firewall on the driver side for my amp steps,brutal.
    2. Make sure you get a camera that supports front view, my first purchase was a bust. There are a lot of Natika models on Amazon so pay attention. I went with their license plate version. I thought the long horizontal mount would give be better options on my TRD progrill and it does.
    3. The activation switches, my Limited DC cab with the knight rider light bar has zero available locations so I had to get creative. I do not like the location of the light bar switches they are hard to see and get to. So I decided between ease of use and my ability to easily replace the interior piece back to stock if needed. Picture below, I like the location and honestly what a worthless tray
    4. Camera location, I had no idea other than trying to center and wing it. I highly recommend you keep plenty of slack under the hood should you decide to relocate like I will be. Also my first try I didn’t even need to take of the grill just zip tied it on it’s plenty secure. As you can see from the pic I either have it too high or upside down or both lol! I will be lifting/leveling the truck 2.5” in the next couple weeks so it would only get worse. I’m not sure about the guide lines I have the ability to cut the wire and remove completely, but I’m going to wait and see how relocation goes first. You can see in the pic where it is now blue circle, the red circle below the garnish will be my next try.
    This a nice kit well thought out and worth the cost. If I had any suggestions / questions it’s only 3.
    1. Another foot or two on the activation switch leads would be nice as I had to go further. Not a big deal I have plenty of connectors so I just spliced some more on.
    2. If possible? Could you offer another version that gave you either a physical cable for phone/accessories hook up or even better casting? I hear the screen res on the stock is not so good but hey if I’m just killing time I’m not going to really care. I’d assume this would be more $$ but given the option I’d go for upgrade version.
    3. Is there a way to record either by camera upgrade with like an SD card or a different circuit board for a future version of the harness. In my motorcycle accident I was running a GoPro and I would of been screwed because there would of been no evidence I was run off the road. This would be a huge ability I’m willing to pay for.
    Thanks again Lou!
    Ely010606 and Yzed608 like this.
  21. Jun 10, 2020 at 8:45 AM
    #1371
    pnw.tundra
    pnw.tundra PNW Tundra
    Paul
    PDX
    2022 TRD Pro | Prev 2020 Tundra aka Blue Whale
    Great thread, but I got a lot to catch up. New 2020 tundra owner here - has anyone hooked the on/off to a switch pros?
  22. Jun 10, 2020 at 10:01 AM
    #1372
    azTony
    azTony member since sept, 2017 and over 1,600 messages
    Tony
    Sun Lakes, AZ
    SwitchPro is just a switch. I have not because that is an expensive switch for a camera
    Tchase and pnw.tundra like this.
  23. Jun 10, 2020 at 3:36 PM
    #1373
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Yes. I know of a few customers who have done that. I also include instructions for how to connect to a Switch Pros in the FRAC installation manual.
    pnw.tundra[QUOTED] likes this.
  24. Jun 11, 2020 at 7:02 AM
    #1374
    Sh5rw9nd
    Sh5rw9nd New Member
    Southern Maryland
  25. Jun 11, 2020 at 7:04 AM
    #1375
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    All the hook ups look correct and the most important thing is it states it will do front view. I'd say 99.99 it will work.
    Sh5rw9nd[QUOTED] likes this.
  26. Jun 12, 2020 at 6:12 AM
    #1376
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Looks like it should work. I also noticed yesterday that the Natika Front/Rear cam is available again on Amazon.
  27. Jun 12, 2020 at 10:25 AM
    #1377
    Sh5rw9nd
    Sh5rw9nd New Member
    Southern Maryland
    This the one in which you are referring too?
    Backup/Front/Side View Camera: No Distortion Effect Starlight Night Vision HD Waterproof IP69K Metal Flush or Bracket Mount NATIKA Reverse Rear View Backup Camera for Cars Pickup Trucks SUVs RVs Vans https://www.amazon.com/dp/B083SF5VVN/ref=cm_sw_r_cp_tai_UO74EbE8ZGNQZ
  28. Jun 12, 2020 at 8:49 PM
    #1378
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
  29. Jun 18, 2020 at 9:35 AM
    #1379
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Is there any way to get the front camera to record ?
    I know exactly jack about squat so I'm asking.
    TundraTex[OP] likes this.
  30. Jun 20, 2020 at 12:22 PM
    #1380
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Yes. There is a mini DVR link in the product window at the bottom of the thread discussion. Using that or a similar product, simply connect the front camera Video RCA plug to the input of the DVR and then connect the DVR output to the Front Cam Video input on the FRAC Harness. This puts the DVR in-line with the Front Cam video and it will record whenever the Head Unit is on. The FRAC Harness powers the front camera whenever the Head Unit has power - even if the front video is not being displayed. So video will be recorded at all times the key is On.
    ForceV4, NewImprovedRon and Newbie_19 like this.
