2013 Rock Warrior Conversion with Headlight Wiring Diagram
Discussion in '2nd Gen Builds (2007-2013)' started by redtundra4x4, Jun 1, 2022.
  1. Jun 1, 2022 at 4:29 PM
    redtundra4x4
    redtundra4x4 [OP] New Member
    I am new to Tundras.com and I wanted to share my Tundra Build. I have the 2014 front conversion, 2014 rear bumper and black TRD grille now. Currently painting the 2014 pickup bed and will install in a few weeks.
    WFD473, B.Ross, Skew12 and 5 others like this.
  2. Jun 1, 2022 at 6:17 PM
    Mattyc
    Mattyc <insert custom title>
    Matthew
    NY
    2008 Limited Rock Warrior
    Not stock
    Couple of questions. How does the bumper fit looking from the side? Also, the Tundra logo, is that just the inserts for the recessed stamp on the 2.5? Looking good
    redtundra4x4[OP] likes this.
  3. Jun 1, 2022 at 6:21 PM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Seen these front end conversions plenty but first i've seen just a rear bumper swap. That looks great, nice work. Have you thought about keeping the red grill surround instead of black?
  4. Jun 1, 2022 at 6:22 PM
    des2mtn
    des2mtn Third Member
    Where my wheels stop rolling
    2004 Black DC Limited 4x4
    Tonto cover
    Welcome aboard and nice work! Looks a lot better with the black TRD grille. :thumbsup:
  5. Jun 1, 2022 at 6:25 PM
    redtundra4x4
    The front 2014 bumper fits good if you have the 2014 grille otherwise there will be a gap under the 2013 grille. The rear bumper fits a little tight on the sides and scratches the 2013 bed a little so I bought a 2014 bed from the salvage yard and it’s waiting to be painted. I had the rear 2014 bumper for a year and it looked fine from a distance. If you get some thick washers / spacers for the main rear bumper bolts, it won’t scratch the bed from the sides because it needs to be out a little further so it won't touch the pickup bed. The Tundra tailgate logo on the bed are raised metal letters I got from Amazon.
    des2mtn likes this.
  6. Jun 1, 2022 at 6:56 PM
    Tundra1D6
    What items were needed to do the complete conversion?
    What’s the process on wiring the headlights and fogs?
    Did you put vinyl on the taillights?
  7. Jun 1, 2022 at 7:04 PM
    The best part is you still have the cup holders in the rear door pockets that the rest of us don't have.
  8. Jun 1, 2022 at 7:28 PM
    redtundra4x4
    I vinyl wrapped the bottom half of the tail lights. The front fenders, grille and hood bolt right into the existing factory location without cutting or drilling. The 2013 hood brackets work but getting 2014 hood brackets would make it more flushed. The headlight wiring is a little tricky but I believe there are conversion wire kits from 2013 to 2014 out there and also YouTube videos to help with wiring. I just tapped into the wires using wire splicers instead of buying a kit. I posted a link of a video that helped me with the wiring splicing.
    https://www.youtube.com/watch?v=SMQxjGgtr3s
    https://www.youtube.com/watch?v=RbFJ4tibLVg
    PNWtundrite and des2mtn like this.
  9. Jun 1, 2022 at 8:04 PM
    Tundra1D6
    Would you happen to have any suggestions on plug and play adapters for the harnesses?
    What would you say is a ballpark for this type of conversion?
  10. Jun 1, 2022 at 8:51 PM
    redtundra4x4
    If you get a package deal at the Toyota recycle for the front end, it would probably be the best route since you can get it all at once. Prices may vary on the conversion but my local recycle dealers was aware of the conversion. As for the headlight, there are different kits since the aftermarket headlights come with different type of connectors depending on if you get running lights or not.
    The parts list
    533010C050 hood
    538120C050 left fender
    538110C060 right fender
    539320C903 left fender extension
    539310C903 right fender extension
    521160C110 left fender extension panel support
    521150C110 right fender extension panel support
    531000C310 grill - this one is chrome
    761800C020 hood bulge - this one is chrome
    Front Bumper Toyota Recycle Dealer
    Headlamp Assembly Right-Hand (TRD Pro)
    Part Number: 81110-0C211
    Headlamp Assembly Left-Hand (TRD Pro)
    Part Number: 81150-0C211
    525210C070 retainer front bumper
    539060C020 radiator left side support
    539050C020 radiator right side support
  11. Jun 2, 2022 at 5:35 PM
    redtundra4x4
    I drew a wiring diagram based on the wiring videos. Our 2013 uses one H4 adapter for the driver's side headlight & one for the passenger headlight. The H4 has to be rewired and it has to be split into a 9006 and 9005 connector for the passengers side as well as the driver's side in the 2014 Tundras.
    des2mtn likes this.
  12. Sep 10, 2022 at 7:23 PM
    redtundra4x4
    Finally got around to painting and installing the new truck.
    DoublePro, Kernal and MaxYota like this.
  13. Sep 11, 2022 at 5:37 AM
    zeekevin
    zeekevin New Member
    How much did that bed cost?
  14. Sep 11, 2022 at 6:53 AM
    redtundra4x4
    I got it from a Toyota Recycler, they have various beds at different prices.
  15. Oct 1, 2022 at 9:41 AM
    msikk
    msikk New Member
    Black grille looks awesome!
  16. Oct 31, 2022 at 8:59 AM
    redtundra4x4
    Found a used tailgate that is going to be painted and installed.
    zeekevin, WFD473 and reywcms like this.
  17. Jan 19, 2023 at 1:28 PM
    redtundra4x4
    Side steps and hood scoop added recently.
    zeekevin likes this.
