2013 rock warrior 5.7 flex, idles fine but stalls when given gas. need help
Discussion in '2nd Gen Tundras (2007-2013)' started by Kgranger, Sep 18, 2020.
  1. Sep 18, 2020 at 9:31 AM
    Kgranger
    Kgranger [OP] New Member
    Kris
    2013 rock warrior
    2” wheel spacers, fender flares
    the truck stalled and died about a week ago, and wouldn't start. got it towed. the next day after work ( truck sat for about 20 hours) started the truck and it ran fine, except when i floored it and the tack hit 3k rpm the truck would stall, if i kept it under 3k it would run great. 2 days ago after driving about 30 miles the truck started to stall out and ran really rough, hooked to a friends computer and was getting a miss fire on cylinder 2,4, and 8. but if I let off the gas and gently pushed the peddle it would go. so I changed out the MAF sensor, same issue. yesterday I changed out all the spark plugs, let the truck idel for about 40 min, and it idled perfect. but when i gave it gas and took it for a test ride, it stalled and would barely move. when i put it back in park it idled perfect, gave it gas and at 2k the engine stalls. any help will be greatly appreciated.
    Fourknights and YardBird like this.
  2. Sep 18, 2020 at 9:48 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Welcome aboard from The Pacific South West.
  3. Sep 18, 2020 at 10:53 AM
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    lots of factors causing it to stall - Bad Gas, Bad Plugs, Bad Coils, Bad Fuel Filter, etc.
    When you replaced the MAF and Plugs, did you try reading the codes again?
    Try to read the codes again, if its still misfiring on cylinder 2,4 and 8, the coils must be bad. Try moving the coils around and see if the codes will follow (move coils 2|4|8 to 5|6|7 then check if the codes will follow).
    Good Luck Troubleshooting it and hopefully you get it fixed. Cheers... :cheers:
    JLS in WA and TheBeast like this.
  4. Sep 18, 2020 at 11:09 AM
    Kgranger
    Kris
    2013 rock warrior
    the coils all looked ok. but will swap them around.
  5. Sep 25, 2020 at 12:23 PM
    Kgranger
    Kris
    2013 rock warrior
    Changed out the coils 1,2,4,8 still stalling. Could it be the fuel pump
  6. Sep 25, 2020 at 3:15 PM
    Kgranger
    Kris
    2013 rock warrior
    If it’s the fuel pump do I need to replace it with a flex fuel pump or can I use a standard gas one
  7. Sep 26, 2020 at 10:04 AM
    Dr_Al
    Dr_Al New Member
    Al
    Get an app like Torque for your phone and a bluetooth OBD2 adapter. With it you can see the sensors. The one I would be looking at first would be the throttle position sensor (I think they still have them but it's most likely part of the throttle body) and the gas pedal. They both should be just variable resistors and if they have a dead spot the computer will adjust the fuel incorrectly which could cause the motor to stall. If they are completely gone I think the computer will throw a code but if one is only sort of working the engine may stall before the computer has time to register it being faulty.
  8. Sep 26, 2020 at 2:13 PM
    Kgranger
    Kris
    2013 rock warrior
    Hooked up and getting 2 codes
    P0171 and p0174. Any thoughts? I have replaced all 8 spark plugs and all 8 coil packs
  9. Sep 26, 2020 at 2:33 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Magnuson Magnum TVS 2650 S/C Sniv's Speed Shop 70mm pulley RCF Throttle Body TRD PRO BBS Wheels TRD Front Sway Bar TRD Rear Sway Bar Fox TRD Pro Shocks Limited mirrors (auto darkening/backup camera/power fold/puddle lights) Limited Grill Mod Automatic Climate Controls Mod Automatic Headlamp Mod Sequoia Transfer Case Mod Sequoia Leather Steering Wheel Mod Sequoia Limited Gage Cluster Mod Sequoia LED Headlamp Upgrade Window Tint 15/70% Fake Manual Transmission Mod 10" BAMufflers Stainless Catback Valhalla Catalytic Converter Shields Engine Block Heater Illuminated Ignition Key Ring Mod Deck Rail System w/cleats Solid Offroad Engine Mounts
    Have you poked and wiggled around for vacuum leaks?
  10. Sep 26, 2020 at 2:47 PM
    Kgranger
    Kris
    2013 rock warrior
    Yes, no air leaks
  11. Sep 26, 2020 at 3:34 PM
    Kgranger
    Kris
    2013 rock warrior
    Got some info that some one may have put something in my gas tank. Is there a fuel filter in the tank with the fuel pump? Can I change the fuel filter or do I need to change the whole pump?
  12. Sep 28, 2020 at 11:28 AM
    Kgranger
    Kris
    2013 rock warrior
    Well sugar in the tank is the issue. Now looking for a fuel pump, very difficult to find. Thanks for all your help.
    Geo4x4 likes this.
  13. Sep 28, 2020 at 6:34 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    Ooof, brutal.
  14. Sep 28, 2020 at 6:43 PM
    19crewmaxTRD
    19crewmaxTRD Tundra Enthusiast
    Seth
    2019 white tundra crewmax
    Who did you piss off?
  15. Sep 29, 2020 at 3:54 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    https://www.youtube.com/watch?v=tRM-n15tuXs
    You can look up the TSB on the fuel pump and flex fuels, some were faulty, but I can't remember what years.... You can get lucky and be one of the impacted ones and get a free pump...
