2013 Flex fuel Optiron cluster
Discussion in '2nd Gen Tundra Parts Marketplace (2007-2013)' started by e30cabrio, Aug 17, 2022.
Thread Status:
Not open for further replies.
  1. Aug 17, 2022 at 4:47 PM
    e30cabrio
    e30cabrio [OP] I'm e30cabrio, I'm a modaholic
    West Valley, Phoenix, Az.
    2010 Crewmax, 2013 Sequoia Limited
    Sequoia LED Headlights! D.T. L.T. headers, dual exh., BDX, S&B intake, 2018 seat skins.
    From my 2013 Sequoia, 131/132k miles don't remember.
    I also have a new unopened lens. looking for 200 shipped to the continental US New Optiron lens.jpg
  2. Aug 19, 2022 at 2:34 PM
    1BadTundra
    1BadTundra New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Too Much to List
    Does this one have the Trans temp gauge in it?
  3. Aug 23, 2022 at 8:04 AM
    e30cabrio
    Sorry, I did not see your question, yes it does. This was taken when I got the truck.
  4. Aug 23, 2022 at 8:12 AM
    1BadTundra
    Clinton
    Too Much to List
    I read on here that the Sequoia and Tundra clusters are not compatible... Can you confirm this? I want to put this in my 2010 Rock Warrior.
  5. Aug 23, 2022 at 8:23 AM
    e30cabrio
    I had a 2010 Tundra that I put an Optiron cluster in and it's cluster worked in my Sequoia (I gave it away and tested it first) so I'd say it will be ok.
  6. Sep 3, 2022 at 5:42 AM
    e30cabrio
  7. Sep 15, 2022 at 8:28 PM
    e30cabrio
  8. Sep 23, 2022 at 4:05 PM
    1BadTundra
    Clinton
    Too Much to List
    Fair enough... I'll take it, but if it doesn't work in my 2010 Rock Warrior, will you take it back and send my payment back? I'm a master electrician and owned my own detailing/aftermarket performance shop since 2018. I have been doing this stuff since '95. I can assure you I will be careful with it, but absolutely do not need a $200 paperweight laying around in my shop if it doesn't fit. Let me know.
  9. Sep 23, 2022 at 4:19 PM
    e30cabrio
    That’s fair.
  10. Sep 25, 2022 at 4:25 PM
    e30cabrio
    Non flex will show fuel 1/4 (or so high) Otherwise they work. But unless you want to be empty when the gauge says there is 1/4+ tank this is not for you.
  11. Sep 27, 2022 at 4:53 PM
    e30cabrio
  12. Oct 6, 2022 at 6:48 AM
    Slim Gym
    Slim Gym New Member
    2013 Tundra DC 4X4
    Here is a list for Tundra's of which vehicles need which cluster based on accessories and options. I don't see your number 83800-0CK30 on the list. Must be a Sequoia part number?? I figure it would work in the right truck, depending on above options/criteria.
    e30cabrio[OP] likes this.
  13. Oct 6, 2022 at 6:58 AM
    e30cabrio
    Yup it's a Sequoia specific pn. A Sequoia Optiron cluster worked in my 2010, the orange 2010 worked in my Sequoia.
    The issue is flex. If your Tundra isn't flex gas will read 1/4 low. You can add 100 ohms to the circuit and fix it.
  14. Oct 7, 2022 at 7:54 AM
    thumper_racer
    thumper_racer Not a New Member
    TN
    2012 MGM Rock Warrior
    Hey, if it is still available I'm interested. My truck is a flex fuel, but I am in the same boat as 1BadTundra was if it doesn't work in my truck would you take it back?
  15. Oct 7, 2022 at 3:04 PM
    e30cabrio
Thread Status:
