2012 Tundra crank no start
Discussion in '2nd Gen Tundras (2007-2013)' started by dotches, Feb 16, 2024.
  1. Feb 16, 2024 at 11:41 AM
    dotches
    dotches [OP] New Member
    Intermittent crank no start. Fuel pump relay not energizing. Been in Toyota shop multiple times for nothing!! Any guidance appreciated.
  2. Feb 16, 2024 at 12:12 PM
    Dillusion
    Dillusion New Member
    Kyle
    2019 SR5
    Not energizing as not getting voltage or no voltage.
  3. Feb 16, 2024 at 12:53 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Look up the Fuel resistor sitting I believe on the passenger side bed side, it appears that's mainly the issue on your series of trucks. Very similar to the fuel pump ECU or fuel pump resistor. Look that up and you will probably find your answer. Best of luck.
  4. Feb 16, 2024 at 12:56 PM
    MaineTundy
    MaineTundy 285/65/20 KO2- 34.6”. 35’s fit stock!
    2012 Rock Warrior / 2024 Limited CM 6.5, TRDOR
    Tow Hooks! 285/65/20 KO2 Yakima Rack Carlinkit Carista tweaks
    Bob and AZBoatHauler[QUOTED] like this.
