2012 Tundra +18 offset fender flares
Discussion in '2nd Gen Tundras (2007-2013)' started by Cg13055, May 11, 2021.
  1. May 11, 2021 at 9:40 AM
    Cg13055
    Cg13055 [OP] @yota.parts.distributor
    South Florida
    Mcfly Tundra @yota.parts.distributor
    2012’4.0 Tundra-2004’4.7 crewcab-2021 2.7 Tacoma
    So I just ordered some 18x9 +18 offset methods for my truck, I was thinking of getting fender flares but I have not gotten the rims yet so I don't know how much they will stick outside of the fenders, simply put I don't want to get them if it will take away from the stance of the truck which was the whole point of the new rims in the first place. Also all the fender flares I've found are pretty thick compare to what I want so I have a feeling it won't be applicable in m situation
  2. May 11, 2021 at 10:33 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Cg13055[OP] and Black Wolf like this.
  3. May 12, 2021 at 3:57 PM
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    old set up +18 and Bushwacker flares.
  4. May 12, 2021 at 5:17 PM
    SrgJigPog
    SrgJigPog New Member
    '23 Tundra Limited Trd Off Road
    I’m in the same boat. Have a set of 18x9 +18 MR316 on order and bushwacker oe flares on order. Can’t decide on tire size.
    Cg13055[OP] likes this.
  5. May 12, 2021 at 7:34 PM
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    35s
  6. May 13, 2021 at 6:18 AM
    SrgJigPog
    Not interested in a body mount chop. Don’t really even want to level the truck. If I do lift front it will be with the lowest setting on either the 5100/6112 setup
    vq35721[QUOTED] likes this.
  7. May 13, 2021 at 9:32 AM
    Cg13055
    South Florida
    18x9 703 gloss titanium in transit +18 Thinking it won't stick out enough for fenderflares on metric tires. I'm not into how beefy the bushwackers are and I don't want to drill holes in the body either, the stick on have issues with conforming to the body. Looks like I will be sticking to stock unless I end up going another way
  8. May 13, 2021 at 9:33 AM
    Cg13055
    South Florida
    what lift? looks pretty good
  9. May 13, 2021 at 10:25 AM
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    ProComp 4inch
  10. May 13, 2021 at 11:11 AM
    SrgJigPog
    Part of the reason I ordered the flares is because my stock wheels with stock size KO2 have a lot of paint damaged on the trim of the wheel well. I ordered the smallest ones which stick of .75” so figured that would be good with the +18 wheel.
