2012 shut off while driving will not restart. Replaced battery, still wont
Discussion in '2nd Gen Tundras (2007-2013)' started by Pa Jesse, Jun 20, 2020.
  1. Jun 20, 2020 at 11:58 AM
    Pa Jesse
    Pa Jesse [OP] New Member
    David
    Not showing any error code
  2. Jun 20, 2020 at 12:58 PM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    Have you checked the negative battery cable ?
  3. Jun 20, 2020 at 1:02 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Does it crank? Or what is it doing? If it’s cranking and not turning on my guess is fuel pump
  4. Jun 20, 2020 at 1:03 PM
    pickupjason
    pickupjason New Member
    2019 Silver Crewmax TRD offroad 4x4
    Does it turn? There are couple things you need to get the car started, I am sure it will be easier for fellow members to offer helps if you could let us know mow information.
  5. Jun 20, 2020 at 1:53 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Did anyone try to jump start the truck after it stopped on you? If the cables were attached backwards, that will blow the main fuse or fusible link in the underhood fuse box. Check all the fuses while you're looking, there may be other blown fuses in the fuse box.
  6. Jun 20, 2020 at 2:21 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Also a loose intake hose will brick the truck. Check everything is right under the hood.
  7. Jun 20, 2020 at 2:54 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    We are going to need a lot more information to be able to help you with this.
    see the above posts.
    Tundyfundy and BravoDeltaRomeo like this.
  8. Jun 21, 2020 at 5:06 AM
    Pa Jesse
    David
    Here's facts, 2012 Toyota Rock warrior, 42,956 miles, never beat up off road. Nothing has been modified from original equipment. Just driving down the road on real nice day at about 45 mph and the engine just shut off. Glad we were not on an interstate, it could have caused an accident. Tried to read fault codes but none show up on a code reader, (I will try a different reader). I replaced the battery, cleaned all terminals, checked voltage at many places (full voltage everywhere I look). We can hear the fuel pump run as soon as the key is turned, the engine turns over (sometimes it will almost start but just shut back off). Any suggestions to check?
  9. Jun 21, 2020 at 5:18 AM
    JohnLakeman
    With a new, fresh battery, cranking speed should be high. If it's not cranking vigorously, I would check the battery cables' condition, and clean the ground cable termination on the chassis. Battery cables can corrode under the insulation. Look for any lack of flexibility in the cables, or non-uniformity of cable insulation (lumpiness).
  10. Jun 21, 2020 at 6:00 AM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    Just a wild shot in the dark but could something have happened where the ECU can’t read your key now after the battery swap? Idk. Just spitting in the wind but I’m wondering if it’s the transponder acting up.
    ZappBrannigan likes this.
