2011 Transmission
Discussion in '2nd Gen Tundras (2007-2013)' started by Ruger2506, Jun 15, 2018.
  1. Jun 15, 2018 at 9:07 AM
    Ruger2506
    Ruger2506 [OP] New Member
    So I run a 2011 Tundra TRD Rock Warrior package. I have the typical Tundra tranny slip. My question is........what is it going to cost me to have a tranny guy drop the tranny and fix the problem?
  2. Jun 15, 2018 at 9:17 AM
    LML 3500HD
    Not typical dude. One hardly ever reads about transmission issues in a Tundra.
    Might I suggest you call your local transmission shop. Sounds logical.
    trayday and Prostar 190 like this.
  3. Jun 15, 2018 at 10:09 AM
    Ruger2506
    Dude, do a Google search. Many, many, many people have the slipping tundra transmission before it warms up.
  4. Jun 26, 2018 at 6:04 PM
    Dmas
    Dmas New Member
    FTL, FL
    2018 SR5 Tundra DC TRD Off Road 4x4
    How many miles on your transmission? A fluid and filter change can fix or improve the issue.
  5. Jun 26, 2018 at 6:45 PM
    Ruger2506
    I read they are closed systems. Have to take tranny out to access fluids and filter.
  6. Jun 26, 2018 at 7:35 PM
    Dmas
    Dmas New Member
    FTL, FL
    Not really , they don’t have a dipstick to check fluid level. What they usually do is remove the transmission fluid oil pan to replace filter and change the fluid.
  7. Jun 27, 2018 at 2:45 AM
    Ruger2506
    Ah, thanks for the clarification.
  8. Jun 27, 2018 at 3:06 AM
    LML 3500HD
    Now why do you think that is? Hummm...doesn’t fluid expand when warm/hot?
    Usually this is a fluid level issue (low level). I don’t need to do a google search, only the people that skip services (30,60,90) have transmission problems, and get them resolved after a quick fluid level check or service. My 12’ was a little low at the 30k mile service check.
    Not knowing that the Tundra transmission doesn’t need to be dropped for a service makes me suggest you do some reading up on this site (or maybe a google search) and educate yourself. This probably is out of your scope of troubleshooting, and a transmission shop/dealership is probably your best option, as it is with 98% of Tundra owners due to the complexity of ensuring the level is correct.
    To answer your original question, it costs 199.00 for a fluid drain, fill, system check.
  9. Jun 27, 2018 at 3:30 AM
    Ruger2506
    No question dude. I hate wrenching.
  10. Oct 9, 2018 at 3:47 AM
    BlackSheep
    BlackSheep caffeinated member
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    held together by duct tape and baling wire
    My truck is currently in the shop after having the transmission drained and refilled a couple weeks ago and a new filter installed. It was a little overdue for service, but I wasn’t experiencing any weird behavior. After getting it back, I noticed the truck would roll backwards on inclines before accelerating from a stop where it had never done that before. And shifting from 1st to 2nd was noticeably delayed from what I’m used to, and the engine would stay revved up for much longer than it used to. I took it back in and the shop says everything looks normal, except the fluid was foamy when they checked it. Today they’re supposed to put a Toyota transmission filter on it to see if that fixes that issue. Idk what they put on it initially. But I’m worried I may have created problems where there were none before!
  11. Aug 27, 2023 at 7:31 AM
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    You can pull the Allen key out of the transmission pan and check your fluid in the garage.
  12. Aug 28, 2023 at 10:51 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Little more to it than that.
    The trans must be in a specific temperature range in order to use the leveling procedure (overflow from the hex plug). This temperature is NOT operating temp.
    A quick search of the process will yield a few acceptable methods of performing this level check.
    Transmissions are expensive. I do not recommend anyone unfamiliar with the process mess with it. That would be a good means of achieving an incorrect ATF level which will cause shifting problems just like the person a few posts back seemed to experience.
    Many do not recommend pulling the pan and messing with the filter unless it's a last resort. Drain and fills with the correct leveling procedure has a well proven track record.
  13. Aug 29, 2023 at 5:54 AM
    Vince
    Vince New Member
    Vincent
    Then again you can check it in the garage just follow the procedure for the fluid level checking. I have mine serviced every 100000
  14. Aug 29, 2023 at 6:13 AM
    CMikeB
    CMikeB New Member
    Hey Vince, that avatar of yours made me smile. Especially the little critter with the white cap!:D
  15. Aug 29, 2023 at 7:14 AM
    Ericsopa
    Ericsopa Old man and the sea
    The Tundra 6sp Aisin transmission doesn't have a slippage problem, unless it's been abused or neglected ....... dude.
  16. Aug 29, 2023 at 7:51 AM
    COTundie
    Trey
    Pretty things
    Not arguing the check/service can't be done at home in one's garage. That's where I do mine... But I've educated myself on the correct procedure.
    Just didn't want anyone reading the post and unscrewing the overflow to "check" their fluid level, only to lose fluid out of a transmission which was already at the correct level.
    Simply attempting to limit confusion on a process which is not very straightforward.
  17. Aug 29, 2023 at 8:29 AM
    EmergencyMaximum
    EmergencyMaximum New Member
    If the fluid was foamy, perhaps it had low level?
  18. Aug 29, 2023 at 12:02 PM
    BlackSheep
    Scott
    Kansas City, MO
    Guess I should respond at this point. Since the shop put in the Toyota ATF filter, my truck has run like new and now has over 160k on it. The last 45k or so have all been on 37s.
    I have been thinking it is about time to do another drain and fill, specifically ordering a new Toyota filter rather than whatever budget option the shop would normally put on.
    EmergencyMaximum likes this.
  19. Aug 30, 2023 at 8:51 PM
    Sierramare’
    Sierramare’ New Member
    Ted
    Alaska
    2007 SR5 DC 4wd
