2010 seat replacement
Discussion in '2nd Gen Tundras (2007-2013)' started by Florida man9863, Oct 19, 2021.
  1. Oct 19, 2021 at 4:07 PM
    Florida man9863
    Florida man9863 [OP] New Member
    Bill
    I need to replace the drivers seat. I have a munual seat, but the wiring and the fuses are there for a power seat. Can I replace with a power seat? Does anyone know where I can see a video of seat removal and replace?
  2. Oct 20, 2021 at 8:44 AM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    Seat removal an installation is pretty self explanatory. I think there are only four bolts. Be sure to disconnect your battery and let the truck sit for 20 minutes before you unplug the harnesses from the seat so the SRS system stays happy.
    If the seat upholstery is worn, you can just replace that, but it is a lot easier with the seat out of the truck.
  3. Oct 20, 2021 at 8:53 AM
    Florida man9863
    Bill
    Thanks, I would like to put a power seat in if it will bolt up the same.
