2010 Platinum Build
Discussion in 'Sequoia Builds' started by richardo, May 13, 2020.
  1. May 13, 2020 at 5:38 PM
    richardo
    richardo [OP] New Member
    Richard
    2010 White Sequoia
    Step 1 stock Platinum
    Step 2 TRD PRO wheels
    S. Equoia, omgboost, Bama and 4 others like this.
  2. May 14, 2020 at 8:34 AM
    Bama
    Bama Member
    2016 MGM Tundra 2015 MGM Sequoia
    Really nice. Love those wheels! I've been looking for some myself. Is the rear lifted?
    richardo[OP] likes this.
  3. May 14, 2020 at 8:39 AM
    richardo
    Richard
    2010 White Sequoia
    Thank you, no and yes lol, Have the rear air suspension adjusted, but have my complete lift kit with suspension ordered and hope to have it and on by the end of this month. I was very lucky to find these with only 20 miles on the tires.
  4. May 14, 2020 at 9:33 AM
    Bama
    Bama Member
    Oh yes, forgot about the Platinum air susp. Great score on the wheels. What lift did you go with?
  5. May 14, 2020 at 9:41 AM
    richardo
    Richard
    2010 White Sequoia
    2008-2020 Sequoia 2.5" Lift With SPC UCAs
    Strut Assembly With New KYB Strut Mounts - $159.99: Yes, I'll add strut assembly with new KYB strut mount for $159.99
    SKU: 2ndGenSeq2.5Lift/SPC/StrutMoun
    I have to get the rear spring seats/seals and going to have the front end checked out as well to be sure nothing needs to be done before installing.
    Then I have to decided whether I am will convert the front end to a Tundra or not. I have been researching parts list, but have yet to find a one.
  6. May 21, 2020 at 11:24 AM
    ccheezy
    ccheezy New Member
    North Carolina
    2020 CrewMax Limited
    "What are you hauling there son?" "ass"
    That thing is a unit, what is next?
  7. May 21, 2020 at 11:29 AM
    richardo
    Richard
    2010 White Sequoia
    Just the 2.5 lift and 1.25 wheels spacers. I am back and forth about fender lining from Bushwacker or anyone else. Considering Tundra front end swap or convert Headlights to the 2018 and TRD Pro Grille
  8. Jul 16, 2020 at 6:31 AM
    richardo
    Richard
    2010 White Sequoia
    Update lift kit installed!
    Now to figure which headlights are the best quality and what grille to get and how it fits. 333CA796-E4B2-462C-A20B-2F375B3255F4.jpg 1FD3F801-C6AF-4FC0-BC2A-BB8036950FFB.jpg
    toyofan87, S. Equoia and War Machine like this.
  9. Jul 16, 2020 at 6:59 AM
    Beau
    Beau De gustibus non est disputandum
    Beau
    2008 Sequoia with a 2022 style
    Looks great! Keep us updated on the progress.
  10. Jul 21, 2020 at 11:56 AM
    jkorey
    jkorey New Member
    Super nice Sequoia. I love the way it looks! Is that lift from 1stgenoffroad? I have the Dobinsons 2.5 springs and shocks about ready to go on my 08 Sequoia Limited. What is the total height ground to roof with the lift? I wondering to see if it will still fit in my garage after the lift. How does it ride?
  11. Jul 22, 2020 at 9:53 PM
    gjb777
    gjb777 New Member
    Gabriel
    08 Sequoia Big Blue
    Custom paint, wheels, icon suspension, JBA uppers, Katzkin interior, rigid lighting, Kicker System
    What shocks did you get with those Dobinsons? Can’t seem to find anything that allows for 2.5” over stock
  12. Jul 22, 2020 at 9:54 PM
    gjb777
    gjb777 New Member
    Gabriel
    08 Sequoia Big Blue
    Looks awesome! Tip on headlights, the Morimoto’s are the best.
    Also, what did you go with for the lift on the rear? Which spring and shock?
    richardo[QUOTED][OP] likes this.
  13. Jul 23, 2020 at 4:21 AM
    jkorey
    jkorey New Member
    I purchased the the Dobinsons shocks for the sequoia that is listed for with 1.77" lift kit from Dobinsons. 1stgenoffroad has the same shocks listed with their "put together" kit with "2.5" Dobinsons springs, before he started offering the 5100s for the rear.
    gjb777[QUOTED] likes this.
  14. Jul 23, 2020 at 6:01 AM
    War Machine
    War Machine SSEM # 5 3MW
    Nice!
  15. Jul 25, 2020 at 8:47 AM
    richardo
    Richard
    2010 White Sequoia
    Thank you. I purchased a complete kit from 1stgenoffroad and I had to go with the one for rear air suspension. Front sits higher than the back assume that’s just a settling issue but if not I’ll get the ICON front coil overs. Thank you for the head light info!
    I can’t decide whether to paint the front grille black or swap out to the tree pro grille. Hate to spend $ and it doesn’t fit right
  16. Jul 25, 2020 at 2:16 PM
    jalam321
    jalam321 New Member
    Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    Looks good, how does it ride/drive?
  17. Jul 25, 2020 at 2:19 PM
    richardo
    Richard
    2010 White Sequoia
    Front bounces a lot but slowly settling in. Back seems to ride smoother. If the front doesn’t settle close to level with the back will replace with the ICON coilovers. I will be putting on 35s maybe just tires for now then wheels later on. Depends what I find and the cost.
  18. Jul 28, 2020 at 7:00 PM
    ZacMaster
    ZacMaster New Member
    2011 MGM Platinum Sequoia 4WD FFV
  19. Jul 29, 2020 at 4:43 AM
    richardo
    Richard
    2010 White Sequoia
  20. Aug 3, 2020 at 10:38 AM
    Adamdsgn
    Adamdsgn New Member
    2018 Toyota Sequoia
    How does lifting the rear of a Platinum effect the air suspension or did you remove the air suspension? I have never seen or hear of anyone putting a lift on a Platinum (just SR5 and Limited) because of the air suspension.
    Honestly I didn't think it was possible. After seeing this it obviously is and I'm intrigued. I searched forever for a Limited because of the difference in rear suspension between the Limited and Platinum, but had to end up settling for a Platinum.
  21. Aug 3, 2020 at 10:40 AM
    richardo
    Richard
    2010 White Sequoia
    I removed it and replaced it with the spring seats, springs and shocks. I almost did what you did but found the deal on the Platinum and went with it.
  22. Aug 3, 2020 at 10:53 AM
    Jbtaco2002
    Jbtaco2002 Almost a Tundra
    San Diego
    nothing cool
    the 35's will take away the illusion of the lift, it did on mine! the gap between your tires and fenders looks massive with those stock tires! lol
    good start on the build tho :cheers:
  23. Aug 3, 2020 at 11:26 AM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    tundra front end swap, so sexy!
  24. Aug 5, 2020 at 5:53 AM
    Adamdsgn
    Adamdsgn New Member
    2018 Toyota Sequoia
    Thanks for the info. Same on the Platinum, we found a deal on a 2018 4x4 that I couldn't pass up. Finding a Limited with reasonable low miles that is a 4x4 and has the second row captains chairs is damn near impossible. I found 3 in the US and was prepared to fly one way to pick one of them up and drive it back, but they sell within 24 hours. Their damn near unicorns.
  25. Mar 2, 2021 at 9:40 AM
    UpInSm0kE
    UpInSm0kE New Member
    Build looks great man, With removing the rear air suspension and oem shocks are you throwing any codes or warnings in the cluster?
    Sandlaut likes this.
  26. Mar 26, 2021 at 8:11 AM
    richardo
    Richard
    2010 White Sequoia
    I have not had any issues with replacing/removing of those parts. Thank you for the compliment.
  27. Apr 3, 2021 at 3:32 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    No codes, they are completely separate system.
  28. Apr 3, 2021 at 3:46 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Noice...
  29. Oct 28, 2022 at 7:27 AM
    joshsequoia 1017
    joshsequoia 1017 New Member
    Joshua
    2012 sequoia 4x4 platinum
    what exact kit did you purchase for the front lift?
  30. Oct 28, 2022 at 7:33 AM
    DBLTRBL
    DBLTRBL New Member
    Bill
    Iowa City
    2016 sr5 Crewmax TRD Off Road
    de-badged, hood decal, Pro Headlights, Paint Match Pro grill and hood. DVD monitors. neoprene seat covers, weathertech floorliners
    Love the Sequioa! Should be a fun build for you. Someday, I hope to convince my wife to get outta her Highlander and into a Sequioa.
