201,000 miles....is it time to change brake and power steering fluids?
Discussion in '1st Gen Tundras (2000-2006)' started by Bought2Pull, Mar 18, 2025.
  1. Mar 18, 2025 at 7:32 AM
    Bought2Pull
    Bought2Pull [OP] New Member
    Greg
    WV
    2006 Tundra 4 door
    2006 Tunda being rollbacked into the shop for timing belt, water pump, radiator, O2 sensors, tie rods, alignment, parking brake....
    Should I go ahead and have brake and power steering fluids changed too?
  2. Mar 18, 2025 at 7:39 AM
    ATBAV8
    ATBAV8 Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    2003 V8 SR5, Access Cab, 4x4, White
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
    Seems like you're already giving them a shitload of money; so why not? Especially if both of those truly have over 200K. WAYYY overdue...Personally I would do these myself, not hard.
    The Black Mamba likes this.
  3. Mar 18, 2025 at 8:17 AM
    Fragman
    Fragman New Member
    TX
    2006 Tundra DC SR5 2WD V8
    Fluids are not just mileage dependent, but time dependent. Brake fluid especially. It will absorb moisture. Every two years or so if you live somewhere hot and humid like I do. You can go longer, but it's really not hard to do and both power steering fluid (Dexron ATF) and brake fluid are cheap.
  4. Mar 18, 2025 at 8:20 AM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    I added these to the written list I'll present to the service dept. desk this afternoon.
    Might as well....get it done while they have it.
  5. Mar 18, 2025 at 10:38 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  6. Mar 18, 2025 at 4:37 PM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    Good idea! I guess I should do that. How do I do that?
  7. Mar 18, 2025 at 4:43 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Post all of your updates and questions in 1 thread instead of a bunch. Like maybe your "It's happening" thread. You could even edit it and rename it. @KNABORES has a good example here and so does @FiatRunner here
  8. Mar 19, 2025 at 6:57 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    2006 Tundra SR5 Double Cab - 4.7L V8 4x4
    I'd definitely change the fluids out, way overdo, and both are easy to do with basic tools.
