2008 Tundra P300 - Frustrated!!!
Discussion in 'Performance and Tuning' started by larlap, Apr 26, 2020.
  1. Apr 26, 2020 at 2:51 PM
    larlap
    larlap [OP] New Member
    Larry
    Illinois
    2008 Toyota Turnda
    New member. Reviewed may posts in the past. Great threads!
    2008 Tundra Limited 5.7
    I originally threw P0335 Code. Changed the Crankshaft Position Sensor. Went away.
    When i went to start, it only clicked. Using Jumper cables, I could crank but not start.
    New battery, new Crankshaft sensor....Now throws a P0300 code, which is vague. also shows a C1201 from the diagnostics.
    Plugs look good, coils look good. I think the fuel filter is in the tank so didnt check that yet.
    Any thoughts?
  2. Apr 26, 2020 at 2:55 PM
    Tundra_power
    Tundra_power New Member
    Nick
    When you try to start it did you hear one click or many clicks. If you heard just one click its your starter. I had the same issue codes pop up saying change your crankshaft sensor if its many clicks i have no clue lol good luck...
  3. Apr 26, 2020 at 8:06 PM
    larlap
    Larry
    Illinois
    2008 Toyota Turnda
    Interesting thought. Yes, it was one click. However, by jumping it, it turned over but doesn't start. I put a gas pressure gauge on the driver side fuel supply and nothing. No fuel... The fuel pump fuse has 12 v in and out.. I'm wondering if my fuel pump failed???
  4. Apr 26, 2020 at 8:10 PM
    Tundra_power
    Nick
    Disconnected the power for 30min and see and try. If its only one click im 100% your starter is gone. It was hard to start for me also at first...
  5. Apr 26, 2020 at 8:13 PM
    Tundra_power
    Nick
    If it doesn't start than turn the key to ON do not start and listening for the fuel pump it should be on to prime the system. If you hear it than turn the key to ON position multiply times to fully prime the system and than start it. If uts start fine its the check valve.
  6. Apr 26, 2020 at 8:18 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    P0335 is Crankshaft position A
    P0300 is Random Cylinder Misfire
    If the truck Cranked and ran before sensor replacement it should run now cause a crank sensor has nothing to do with continuous cranking is it possible you could had run your battery down or possible bad cell in the battery try installing a fresh battery Toyota’s go brain dead when battery drains so when you go start it up make sure all accessories are off including AC and let it idle for 10-15 minutes till it relearns
    BENWALES likes this.
  7. Apr 26, 2020 at 8:47 PM
    Ncherry84
    Ncherry84 New Member
    Nate
    Dickinson, ND
    2020 Tundra SR5 CrewMax Magnetic Gray Metallic
    Stock
    Stupid question, but, did you plug in the new sensor? Or not plug in anything else related to the ignition system in the process of replacing the crank sensor?
    If I had to guess, you cranked it once, failed, if you were to crank it 7 more times it might possibly start. Also, if perhaps the new sensor is bad or not reading and fails an internal test in the ECM or it doesn't see it some vehicles will cut the fuel supply.
  8. Apr 26, 2020 at 8:57 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    Bad battery?
  9. Apr 26, 2020 at 9:21 PM
    Tundra_power
    Nick
    No i replace the starter everything went away.
    Leo's first likes this.
  10. Apr 26, 2020 at 9:25 PM
    Tundra_power
    Nick
    If its one click that the solenoid in the starter thats bad. I had the same exact problem one try to start just a click and another click. Than it started barley check engine light was on but i got code crankshaft sensor. So i replace it and did it again click click than i replace starter everything was fine. But you might have another underlying problem going on here...
  11. Apr 26, 2020 at 9:39 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    @larlap Did you install a genuine Toyota or aftermarket crank sensor? How was the connector / wiring?
  12. Apr 27, 2020 at 8:46 AM
    larlap
    Larry
    Illinois
    2008 Toyota Turnda
    Thanks for all your feedback! New battery. Single click start has been a low battery. Something is draining it. I'm charging it now.
    I was not getting fuel to the fuel rail. I disconnected the fuel quick connect and put the key to on. No fuel. I swapped the relays. BUT....When I engage the the ignition to ON, no fuel comes out. When I crank it, fuel gushes out. I though the fuel pump ran to the ON position!
    The Crankshaft Sensor was a model by Holstien. It was well rated.
    So, now I'm stuck again. Not sure where the ASD relay is but that's where I'm heading. Still confused why fuel isn't sent on the ON key position and sends fuel when cranking. BTW, the cranking lasts for about 10 seconds and stops. As if it's not getting spark....
    The crankshaft sensor clip seated well and clicked. The wiring looked fine behind the protective plate. The code crankshaft code went away. I did the continuity test on the old sensor pins and nothing was shorting.
    Any other ideas?
    It's cranking, sending fuel while cranking, only code is the 300, just not firing...
  13. Apr 27, 2020 at 9:51 AM
    Tundra_power
    Nick
    Maybe try spare key to start the truck. Yes the fuel pump should be running on the ON position.
  14. Apr 27, 2020 at 9:59 AM
    Ncherry84
    Nate
    Dickinson, ND
    Stock
    X2.
    If the anti theft system thinks it's being stolen, there wont be any fuel pump action with the key on because the pickup will think it's being stolen.
    Unless Toyota uses a starter lockout instead, then the key may not make a difference to the fuel pump persay.
  15. Apr 27, 2020 at 10:58 AM
    larlap
    Larry
    Illinois
    2008 Toyota Turnda
    More good thoughts. Thanks. Update...I used the spare key, reset the door locks, closed doors, unlocked. Tested the 7.5 a fuses under e brake. Swapped both relays that control the fuel pump. Well, now it cranks and fires a brief hit during the cranking. I smell gas. It actually sounds like a misfire... I reset the ECM and it still immediately shows the 300 code. I had the battery disconnected for an hour too. I might try to put the old crankshaft sensor in to see if the new one isn't compatible? SO FRUSTRATING!!!
  16. Apr 27, 2020 at 12:09 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    It’s normal that the fuel pump isn’t running until cranking.
    Good idea on re-trying your old CPS. If it starts with that, even if it codes P0335 again, I’d say try a new OEM sensor.
  17. Apr 27, 2020 at 1:11 PM
    larlap
    Larry
    Illinois
    2008 Toyota Turnda
    Update... I put in the old original crankshaft sensor.....IT STARTED... SO, I think the new sensor was not compatible. It did throw a Processor error and run rich bank 1 error. But, I reset all the codes and let it run for an hour. Seems good for now. I'm back to where I started....I'll wait for the cycles to run their course to see if an new error code presents itself.... THANKS FOR THE FEEDBACK!!
    Black Wolf and landphil like this.
  18. Apr 27, 2020 at 2:54 PM
    Tundra_power
    Nick
    Actually it is for a brief second to prime the system like a faint humming noise.. When you turn the key to ON.
  19. Apr 27, 2020 at 2:56 PM
    Tundra_power
    Nick
    Thats great. Actually i have an oem if you want. Replacing mine crankshaft sensor didnt work... So i have an extra one.
    Black Wolf and JLS in WA like this.
  20. Apr 9, 2022 at 10:05 AM
    Bber08527116
    Bber08527116 New Member
    08 tundra
    I'm having similar issues changed fuel pump relays fuses not hearing the fuel pump turn on only runs when it wants weird battery is good didn't run one of the many times and boosted it and started but when it cranks no start def no fuel going to the rail . I don't know what else to do
  21. Apr 9, 2022 at 10:06 AM
    Bber08527116
    08 tundra
    No codes showing
