2008 Tundra, Ingintion Switch gone bad?
Discussion in '2nd Gen Tundras (2007-2013)' started by JamesBB, Dec 9, 2021.
  1. Dec 9, 2021 at 1:19 PM
    JamesBB
    JamesBB [OP] New Member
    2008 Tundra TRD Package, 5.7L
    My problem started with a battery drain, then went to not being able to operate the power windows, and now the truck won't start. The accessories will work, but the ignition will not even try to start the truck.
    1. I am looking for help as how to confirm it is the ignition switch causing the problem, or if it is something else.
    2. If it is the ignition switch, I need help/links to a good tutorial on how to replace it. Is the ignition switch just one component or multiple? Which should I replace? Also, what are the issues with using my old keys vs. new keys? Will the new ignition come with new keys? Will those new keys work in the door lock? Are there other components I should replace if I have the column open?
    I am mechanically inclined, but clueless on this one.
    Thanks for any help you can offer.
    Moxxey4x4 likes this.
  2. Dec 9, 2021 at 1:22 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    If the key turns the lock is not the issue.
    Open the steering column, unscrew the wire harness from behind the lock and see if it can be made to work properly with the tip of the key or a screw driver. Most likely the issue is the contacts inside the switch and you need that harness.
  3. Dec 9, 2021 at 10:43 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    Did you get battery tested? Cables tight?
  4. Dec 11, 2021 at 8:24 PM
    Moxxey4x4
    Moxxey4x4 New Member
    2007 Tundra SR5 crew cab
    Many
    I am dealing with the exact same issue. The battery is good. Cables good. Fuses good. Tried to hook it up to a code reader and the reader won't connect.
    My initial thought is something is blown. My son had tried to jump it with no success after draining the battery.
    Any ideas would be appreciated.
  5. Dec 12, 2021 at 4:55 AM
    Mr2 guy
    Mr2 guy New Member
    Have you tried your spare key?
  6. Dec 12, 2021 at 7:17 AM
    Kiddnapped Tundra
    Kiddnapped Tundra New Member
    Grand Island, NY
    2010 Tundra DC
    Main fuse ? ? ? ?
  7. Dec 12, 2021 at 12:45 PM
    Moxxey4x4
    Many
    How can I check the main fuse? Without removing the box
  8. Dec 12, 2021 at 1:24 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Maybe crossed the terminals burning those big blocked relays.... I am not trying to be a smart ass, but a Triple A tow truck driver did this to my truck.. I was paying attention at the time and noticed some smoking from the battery and was able to rip out the cables before he got back in his truck and hit the gas... Didn't do any damage, but was struggling with batteries at the time.....
