2008 Tundra Cremax w/JBL Aftermarket 8in Sub Replacement
Discussion in 'Audio & Video' started by Panchies, Sep 7, 2020.
  1. Sep 7, 2020 at 8:45 AM
    Panchies
    Panchies [OP] New Member
    2008 Tundra Crewmax
    Stock
    Hello,
    New here and very ignorant in a lot of things but working on reducing my ignorance as I learn more and more lol. I have a question and Ive read some forums regarding similar questions/answers but unsure if it applies to what I am trying to achieve.
    Issue: Stock 8in Sub behind rear seats had a tear in them
    Goal: I want to just swap out the old sub for a new sub
    Current status: Ive just purchased and installed a Subwoofer with the factory plastic box and need to know how to cable it with what I have. Ive read here to cable this in a parallel from the picture.
    I am hearing almost like loud hiccup sounds when i turn the music up or turn the bass up, what did I mess up? Should this be in a series?
    Would my current factory amp(if any) support this speaker?
    Any help would be greatly appreciated.
    Thanks!
    Panch
  2. Dec 10, 2020 at 2:23 PM
    bluevwfan
    bluevwfan New Member
    Jonathan
    2008 Limited Crew Cab Tundra
    SABM DAP Tune TRD Intake
    Not sure if you fixed already. But I too used the stock enclosure with a shallow mount. On mine it was hitting the plastic trim in front of the speaker. I created distance between the speaker and the trim by not installing the bottom portion of the push pins and putting a spacer to keep the trim installed.
  3. Dec 10, 2020 at 3:02 PM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    1st post never got a welcome mat...Welcome Op
  4. Dec 16, 2020 at 3:34 AM
    Okie1
    Okie1 New Member
    SW Missouri
    2017 Tundra 1794 Crew
    Following the thread....
  5. May 24, 2021 at 4:18 PM
    m14mike
    m14mike New Member
    2008 Tundra
    Golf Ball Size Hail Maroon
    Hey Panch,
    I just installed a RF Punch P3 8 Shallow Dual 2 ohm (Stock JBL system, stock amp.) I wired it 2 ohms and it sounded like it was also blown. Took it out and re-wired at 4 ohms and now it's perfectly splendid!
  6. May 26, 2021 at 9:38 AM
    Okie1
    Okie1 New Member
    SW Missouri
    @m14mike did replacing the factory with the RF sound better? In your opinion was it a noticeable difference? Of course not compared to new amp, new enclosure, blah blah blah. But could you tell a difference by simply replacing the factory sub?
  7. May 26, 2021 at 11:00 AM
    m14mike
    m14mike New Member
    2008 Tundra
    Well, since the factory sub was blown, yes it sounded much better :headbang:. I've installed several systems, but I'm only replacing the factory stuff when it blows since my Tundra is basically totaled from hail damage. Like I said, the new one sounded blown itself but I had it wired incorrectly. Wired at 4 ohms this sub is worth the money.
  8. May 26, 2021 at 11:39 AM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    I swapped in an 8” Alpine Type S subwoofer into the factory box (had to use a 1” ring spacer) and it is substantially better sounding.
    I also sound deadened the floor and back wall which made a noticeable difference for the factory sub.
    Allrsdup and ToyoElmer like this.
