2008 toyota sequoia won't shift past 4th gear in 4 lo
Discussion in 'Sequoia 2nd Gen (2008-2022)' started by Jbtaco2002, Dec 4, 2018.
  1. Dec 4, 2018 at 7:20 PM
    Jbtaco2002
    Jbtaco2002 [OP] Almost a Tundra
    San Diego
    nothing cool
    so it seems in searching there are other issues that may prevent the transmission from going into 5 and 6th gear, but i appear to be experiencing something slightly different. I have no flashing lights, VSC, etc
    for a year now, i haven't been able to get my Sequoia to shift into 4lo. it just would rapidly flash and nothing happened. yesterday i tried it randomly and i heard the actuator engage and it went in, i was pretty excited.
    today i tried again and it worked, so i went driving in 4lo and in both automatic mode and sport mode, it seems to be "stuck" in 4th gear and won't shift higher.
    i have no issues in 4hi or 2hi. thoughts?
  2. Dec 4, 2018 at 7:22 PM
    Ac91
    Ac91 New Member
    Dallas
    2018 Tundra SR5
    What speed are you trying to go into 4lo?
  3. Dec 4, 2018 at 7:22 PM
    15whtrd
    15whtrd Mr. Blonde
    Mine does the same thing. I’m pretty sure fifth and six gear are both overdrives. I want to say the transmission may not be strong enough for that much torque to the wheels. There’s no reason you should be going that fast in 4 low anyways in my opinion. It’s probably really hard on stuff.
    joonbug and landphil like this.
  4. Dec 4, 2018 at 7:28 PM
    Jbtaco2002
    San Diego
    nothing cool
    like 15-20 mph at that point, maybe 2500-3k RPM's.
    i get it, most real life 4 lo work would be a crawl anyway, but our 2007 4runner didn't do this. just curious.
    thanks for the speedy responses gents
    15whtrd likes this.
  5. Dec 4, 2018 at 7:29 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    You absolutely shouldn’t be going fast enough for the truck to shift into 4th gear in 4low
    FirstGenVol, T-Rex266, gosolo and 2 others like this.
  6. Dec 4, 2018 at 7:30 PM
    Jbtaco2002
    San Diego
    nothing cool
    dammit, i'm supercharged man! lol:turtleride:
    15whtrd likes this.
  7. Dec 4, 2018 at 7:31 PM
    csuviper
    Broomfield, CO
    Tops 30 mph in 4 low in my opinion. I’m curious what Toyota says.
    15whtrd likes this.
  8. Dec 4, 2018 at 7:34 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Please don’t do that. :D
    15whtrd likes this.
  9. Dec 4, 2018 at 7:55 PM
    15whtrd
    15whtrd Mr. Blonde
    4 hi is all you need with the SC! :burnrubber:
  10. Mar 15, 2019 at 9:18 AM
    BigTree
    BigTree New Member
    2016 Sequoia Limited
    My owners manual for a 2016 Sequoia limited says that the transmission will not shift into 5 & 6 when in 4 wheel Low. 4th gear is a
    1 to 1 ratio, 5th and 6th are overdrives. This way, with a 1 to 1 ratio, there's no extra strain (load) trying to run in the overdrive ratios.
    Considering the transfer case ,in Low Range, multiplies the gear ratios by a factor of 2.625. A little more than 2 and a half times per revolutions. Hope this helps explains things.
