2008 Accord 2.4L starter replacement
Discussion in 'Off-Topic Discussion' started by cornwall325, Oct 10, 2021.
  1. Oct 10, 2021 at 5:33 PM
    cornwall325
    cornwall325 [OP] Work in Progress
    2018 Tundra TRD Offroad Limited Crewmax
    Curious if any of you guys have replaced the starter on a 2008 Accord with the 2.4L 4 cylinder motor? Getting ready to swap mine out. My main questions are: What are the torque specs for the air intake plenum bolts and also if it can be done without unhooking the coolant lines, etc on the throttle body? I’ve watched several videos and the one video a guy did do it without unhooking the lines on the throttle body but the car was not a 2008. I’m sure there’s plenty of gearheads on here so I thought I would ask before I dig into it. I’ve gotta get the starter this week and will be changing it out this weekend most likely.
  2. Oct 10, 2021 at 5:37 PM
    Cock-A-Doddle-Do
    Cock-A-Doddle-Do New Member
    Brett
    Cypress, Texas
    2021 TRD Off Road CM -Super White
    Wrong forum
  3. Oct 10, 2021 at 5:48 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    damn.... Honda starters I've never worked on... Looks like a chore, tbh... I saw this guys pulling his, I would separate the throttle body from the intake as to not mess with the coolant... I evade coolant bleeding like plutonium, its easy to bleed, it just takes alot more time..
    https://youtu.be/sZokBUEMF_E
