2007 Tundra Transmission issue
Discussion in '2nd Gen Tundras (2007-2013)' started by Grayfox7, Jan 29, 2023.
  1. Jan 29, 2023 at 4:01 PM
    Grayfox7
    Grayfox7 [OP] New Member
    Chase
    2007 Tundra Limited CrewMax
    Just bought a 2007 Limited 2wd with 168k miles for $7500 knowing the it needs some kind of transmission fix.
    It goes from drive to reverse really hard. It doesn’t do it from park to revere after starting up. It seems to have no torque and kinda sluggish starting to accelerate. After the truck gets going it shifts through the other gears very smoothly and runs well.
    I just got it home yesterday and have yet to investigate. Any help here would be greatly appreciated!
  2. Jan 29, 2023 at 4:10 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    I would definitely start by checking the Trans fluid level first. Its not very difficult, but there is a certain procedure you have to follow to get it right. Lots of great info here if you use the search function, plus lots of great vids on YouTube to guide you through the process. Good luck.
    Sumo91 likes this.
  3. Jan 29, 2023 at 4:24 PM
    Grayfox7
    Chase
    Thank you!
  4. Jan 29, 2023 at 5:31 PM
    Grayfox7
    Chase
    Any other thoughts?
  5. Jan 30, 2023 at 8:14 AM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    ^This. Check the fluid level first.
    Inspect electrical connections to the trans, and all related fuses. Also check any ground wires you can find.
    Electrical gremlins can cause some crazy issues, there were issues on the 6.0 ford trans where the ground current found its way through the internals of the transmission and cooked it, all because of a broken ground wire.
  6. Jan 30, 2023 at 10:26 AM
    Grayfox7
    Chase
    Came back with P0976 Toyota Code - Shift Solenoid 'B' Control Circuit Low
    ane C1201
  7. Jan 30, 2023 at 11:41 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    C1201 is zero point calibration. I have similar issues there.
  8. Feb 1, 2023 at 4:39 AM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    Some have said a drain and fill ( not flush ) has helped
  9. Feb 3, 2023 at 9:07 AM
    Sierramare’
    Sierramare’ New Member
    Ted
    Alaska
    2007 SR5 DC 4wd
  10. Feb 5, 2023 at 2:37 PM
    Grayfox7
    Chase
    Update. It is a solenoid. It has been starting off in a higher gear for a short spurt. Now the concern is if the clutches have started burning out or not. Going to drop the pan Tuesday and we will know more on how we should proceed at that point. If the pan is clean and no signs of metal or black stuff from clutches we will put in solenoid and ride.if we end up having to fix, Is it worth doing the rebuild/reman? It has 168k 2wd limited CrewMax
    WVI likes this.
