2007+ Tundra Rear Hydraulic Bump Stop System
Discussion in 'SDHQ Offroad' started by sdhq_offroad, Apr 11, 2017.
  1. Apr 11, 2017 at 12:35 PM
    sdhq_offroad
    sdhq_offroad [OP] New Member Vendor
    GILBERT, AZ
    While the factory rear bump stops do a satisfactory job of absorbing impacts on a street driven truck, ICON found that there was much room for improvement during spirited driving in rough, off-road terrain. The ICON Vehicle Dynamics 2007-UP Toyota Tundra Rear Hydraulic Bump Stop System was designed to take the off-road capability of the truck to new levels by significantly improving the bottom-out control of the rear suspension and reducing rear end kick. Like all ICON hydraulic bumps stops, these feature both velocity and position sensitive technology which means that as the shaft speed increases and moves through the travel, the force increases exponentially to provide excellent bottoming resistance that won’t negatively affect articulation.
    This hydraulic bump stop system was developed as an OEM replacement, making installation a simple and straightforward bolt-on affair. With no major cutting, welding, or fabrication required you have the option to return the vehicle back to its stock form. The factory rubber bump stops have a limited energy absorption capacity and a rapid release of this energy upon rebound – This translates into a harsh ride and poor handling in rough terrain. ICON hydraulic bump stops absorb and release this energy in a much more controlled manner due to the digressive rebound piston valving, resulting in predictable handling and vehicle dynamics.
    KEY FEATURES:
    • 2.5” travel bump stop reduces rear end ‘kick’ and improves overall performance
    • Position sensitive technology exponentially increases bottom-out resistance
    • Vehicle specific bump stop tune to provide smooth engagement and best ride quality
    • Direct bolt-in to OEM bump stop location makes for an easy and straightforward install
    • Fully reversible to factory configuration with no bed cutting required
    • Heavy duty 1 ¼” CNC machined nitro steel shaft
    • Multi stage CAD plated body for maximum corrosion resistance
    • Double sealed high pressure Schrader valve
    • Operating range of 50 – 250 PSI
    • Replaceable noise reducing striker pad
    • Fully serviceable
    • “ICON 1K” tested under rigorous off-road conditions to validate tune, performance, strength, and durability
    • Made in the USA
    This are currently not yet up on the website, so to order feel free to PM me or give us a call here at the shop (number in my signature).
    Price: $749.95
    15whtrd, 1UPPER, ColoradoTJ and 3 others like this.
  2. Apr 11, 2017 at 12:37 PM
    sdhq_offroad
    GILBERT, AZ
    Unwrapped and ready for install!
    Voyagermike, J4RR3N4 and zcarpenter92 like this.
  3. Apr 11, 2017 at 2:25 PM
    J4RR3N4
    J4RR3N4 New Member
    South east Texas
    14 Tundra
    3” lift on 35’s
    Do you need to cut the bed floor with these?
    Edit. Sorry I seen where it said no cutting of the bed floor
    sdhq_offroad[OP] likes this.
  4. Apr 11, 2017 at 2:28 PM
    sdhq_offroad
    GILBERT, AZ
    Correct, no bed cutting and this gets rid of the factory bump stops.
    T-Rex266 and J4RR3N4 like this.
  5. Apr 12, 2017 at 8:35 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    It looks from the pictures that these don't mount over the center of the springs. If thats the case, these wouldn't interfere with airbags, correct?
    Oops. never mind. I took another look. looks like they won't work if you have airbags.
  6. Apr 12, 2017 at 8:43 AM
    sdhq_offroad
    GILBERT, AZ
    There is a striker plate that slides in between the U-Bolts that this bump stop will strike off of. We haven't done any test fitment, but by the looks I don't think this will work with an airbag set up.
  7. May 28, 2017 at 6:55 AM
    JP711
    JP711 New Member
    2017 Tundra 1794
    Hello, What is the approx shop labor time to install these ? Also a general question on back order time from ICON ... Seems everything
    from them is always 4-6 weeks out after ordering. Then it actually comes in 8 to 9 weeks from order time. Beautiful high quality products
    and i did a video tour of the factory (on you tube) which is quite impressive however I am at a loss to as why their parts are 2.5 months
    in some cases to you from when you order. Thanks if you can answer these questions. Paul
  8. May 28, 2017 at 8:55 AM
    olsin6
    olsin6 New Member Vendor
    Joey
    Mesa, AZ
    2010 White DCSB Tundra
    35" Toyo MT w/ 17" Method Standards Body Mount Chop SDHQ Sliders
    All depends on the shop installing it I guess. I believe we are between 2-3 hours. When we place orders, their 4-5 week lead times have always been pretty accurate. However we stock these on the shelf as we are Icon's largest stocking distributor.
    Can't rush quality products but you have to remember that products are built in batch orders as it is more efficient compared to building stuff one by one.
  9. May 28, 2017 at 11:06 AM
    JP711
    JP711 New Member
    2017 Tundra 1794
    Thanks very much for quick response in answering my questions. Awesome shop and depth of knowledge you guys and reputation
    at SDHQ. Will keep in mind on in stock items. Final question, being in Norcal if you purchase from your shop and ship to CA will I
    save sales tax and just pay shipping ?
    olsin6 likes this.
  10. May 29, 2017 at 3:17 PM
    olsin6
    Joey
    Mesa, AZ
    Correct. No sales tax, just shipping.
