2007 Tundra Engine Replacement
Discussion in '2nd Gen Tundras (2007-2013)' started by Tacoyaki, Jun 16, 2018.
  1. Jun 16, 2018 at 4:13 PM
    Tacoyaki
    Tacoyaki [OP] New Member
    Kelly
    2007 Toyota Tundra 5.7 limited
    I am new to the site and apologize if this subject has been covered before. I want to replace the engine in my 07 tundra. It is a 5.7 with the 5 vin# V. I know the V stand for 5.7, but what does the 5 vin# of Y stand for and can I use it as a replacement engine in my truck. I have found an 2016 engine with low milage but it has a Y vin for the 5th place. what would be required to put the Y engine in my 2007 5.7 with a V for the 5th vin# Any help and would be appreciated.
  2. Jun 16, 2018 at 4:42 PM
    Vizsla
    Vizsla ☠️☠️☠️
    I don’t know V. 5th would be W=flex fuel, Y=non flex fuel on my 12, 16, and 18. Maybe 07 was different?
    831Tun likes this.
  3. Jun 16, 2018 at 11:10 PM
    Nick T
    Nick T New Member
    Nick
    V and Y were both used for the 3UR-FE, the change happened sometime in 2009 or 2010. Pulling the engine is not a small job, it barely fits unless you cut the radiator support or lift the cab. As these trucks are mostly unchanged unless you have some rare option like a rcsb 4x4 5.7 it's usually more cost effective to sell what you have and get a newer Tundra
    Black Wolf likes this.
  4. Jun 17, 2018 at 5:44 AM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    Like Nick T posted above, a cab lift needs to be done. I haven't seen it done any other way. If you have the time, capability, and got a great deal on that 2016 motor.... Do It!
  5. Jun 17, 2018 at 7:47 PM
    Tacoyaki
    Kelly
    I have found a few engines from salvage yards but they are listed with the Y as 5th vin#. Pricing was around $5200 for an 2016 engine with 18,000 miles. Local Toyota shop said would exchange and install the engine for another $!400. The would be with a 6 month warranty. I have considered selling mine and buying another but again, I have not found another Tundra that I could buy that is comparable to an engine swap in value. I appreciate all suggestions and information from all.
    Blueknights75, 15whtrd and Black Wolf like this.
  6. Jun 17, 2018 at 7:56 PM
    Nick T
    Nick T New Member
    Nick
    Where do you live? I would take my Tundra there when it comes time to swap my engine for $400
    Coolhardy likes this.
  7. Jun 17, 2018 at 8:00 PM
    Tacoyaki
    Kelly
    Maybe I hit the wrong key.... should be 1400.... sorry.... but I live in Houston Texas area.
  8. Jun 25, 2018 at 3:10 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    $1400 still seems reasonable. Only if you could get a $2-3 K motor.
    Whats wrong with your present motor?
  9. Jun 25, 2018 at 3:13 PM
    Coolhardy
    Coolhardy New Member
    Harris
    2014 black tundra
    Too many to list
    $1400 is still on the cheap side especially at the stealership
  10. Jun 25, 2018 at 3:17 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Thats what i was thinking. I doubt its a dealership, probably a junkyard shop that does swaps all day long.
  11. Jun 25, 2018 at 4:32 PM
    Brian3UR
    Brian3UR New Member
    2013 Silver Sky DC 4x4
    Drop in K/N filter with TRD airflow accelerator BullyDog GT Tuner 2.5" Suspension leveling kit TRD rear sway bar Line-X bedliner Charcoal Filter (in air box) delete Deleted screen in throttle body gasket Coolant to throttle body bypass LED lighting inside bed and under hood Center console from 2007 Tundra with LED light for cup holder Small amplifier and subwoofer to enhance factory radio BAMuffler TRD Dual Replacement system (on order) LED headlights, fog lights, brake, tail and interior lights Side mirror glass with turn signal indicators (from Platinum model)
    What happened to the engine in your truck? First off, the engine can be removed without lifting the cab but it's no small job. I am a Toyota dealership tech and I've done several of them. My first step is to remove the transmission, which permits the engine to be lifted directly from the vehicle (after removing the hood and the cowl assy.
    dom1n1ck, Yota7 and landphil like this.
