2007 Tundra 4.7 SR5 Valve cover gasket repair
Discussion in '2nd Gen Tundras (2007-2013)' started by zimere0834, Oct 31, 2018.
  1. Oct 31, 2018 at 10:42 AM
    zimere0834
    zimere0834 [OP] New Member
    Harry
    Virginia Beach
    2007 Silver & Black Tundra 4.7 SR5
    Just wondering how difficult a job it would be to tackle right and left gasket? I'm mechanically inclined, just never did much automotive work. 2007 Tundra 4.7 V8 SR5 Single Cab
  2. Oct 31, 2018 at 10:46 AM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Is the 4.7 different then the 5.7
    They say don’t even think about trying the cam tower seals on the 5.7
  3. Oct 31, 2018 at 10:47 AM
    Leo's first
    Groton ma
    By the way welcome and let’s see that 07
    Stormtrooper81 likes this.
  4. Oct 31, 2018 at 10:52 AM
    zimere0834
    Harry
    Virginia Beach
    I'm just trying to do the valve cover gaskets, I don't think I should have to go into the cam tower, at least I definitely hope not..
  5. Oct 31, 2018 at 10:54 AM
    zimere0834
    Harry
    Virginia Beach
    As soon as I can figure out how to post a picture. Lol.
  6. Feb 6, 2019 at 7:29 PM
    Cdennis
    Cdennis New Member
    Cory
    06 tundra
    2” suspension lift
    I just did both sides on mine today,it’s a pretty easy job. I changed my spark plugs while I was at it. About 9 bolts hold on the cover and 4 hold on the coils to the cover. There’s a couple things to look for and make sure of if doing this job. Let me know if I can help..
    rons23 likes this.
  7. Feb 7, 2019 at 11:46 AM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    The 4.7 engines do not have cam towers like the 4.6 and 5.7 engines do. I have replaced the valve cover gaskets twice on the 2006 Tundra I had before getting the 2018. Easy to do, very straight forward, just do a clean R&R.
  8. Feb 7, 2019 at 1:52 PM
    Welcome
  9. Feb 7, 2019 at 5:12 PM
    Rubberdown
    I didn’t have time so I just paid the shop to do it which I never do. I think it ran 250 with parts.
  10. Feb 7, 2019 at 7:36 PM
    Cdennis
    Cdennis New Member
    Cory
    06 tundra
    2” suspension lift
    That sounds like a good deal...
  11. Feb 15, 2019 at 2:05 PM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    Just got the oil changed in my 08 today, 4.7L, and the tech said I needed the valve cover gaskets replaced, at $640. I told him not today!
    Does anyone have pictures from the install? I’m not sure if I want to tackle it or find another shop to do it.
  12. Feb 15, 2019 at 5:54 PM
    Cdennis
    Cdennis New Member
    Cory
    06 tundra
    2” suspension lift
    If you have done any mechanical work at all you can do this job. I did mine a couple weeks ago. What happens is the rubber washers that are on the valve cover bolts (9) get squashed by heat cycling and may only be finger tight due to this, thus causing oil leakage usually right on the exhaust manifold cover. Mine were mostly all finger tight. I suppose you could just re tighten to spec 17ft pounds. I have heard of guys doing this for a temporary permanent solution... hope this helps.
    parker44 likes this.
