2007 Trans
Discussion in '2nd Gen Tundras (2007-2013)' started by Odomsh, May 26, 2023.
  1. May 26, 2023 at 8:10 AM
    Odomsh
    Odomsh [OP] New Member
    2007 Toyota Tundra
    So I see lots of posts on here re: trans. mine needs to be replaced with either a used one w/80k on it, or completely rebuilt for around $7500. Mine has 200k on it. Lights flashing for 4 whl Dr hi and lo.No other codes. I would like some real world thoughts and wisdom if replaced to be able to trust it to pull camper or horse trailer again vs buying newer model. Excellent overall mx history.
  2. May 26, 2023 at 8:26 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR / Austin, TX
    Have you pulled codes with a tech stream or another scanner that will pull non-cel codes? My '07 just needed a shift solenoid.
    Odomsh[OP] likes this.
  3. May 26, 2023 at 9:28 AM
    KeepOnTruckin
    KeepOnTruckin New Member
    Randy
    2010 4.6 4x4 Bare Bones
    Ebay has 5.7 4x4 trans $32oo w 27k miles on it.
    4x4 errors are 4x4 errors that need sorted separately from transmission issues. Has either had any maintenance?
  4. May 26, 2023 at 9:59 AM
    Odomsh
    2007 Toyota Tundra
    Copy on both. Am taking it back in next week so sulk follow with these ques. 4x4 never had any mx, used rarely
  5. May 26, 2023 at 10:02 AM
    VWTim
    Shift solenoid issues will indicate thru the 4wd lights too.
