2007 TOYOTA TUNDRA TRANSMISSION
Discussion in '2nd Gen Tundras (2007-2013)' started by tigerman, Dec 8, 2016.
  1. Dec 8, 2016 at 2:18 PM
    tigerman
    tigerman [OP] New Member
    2007 Toyota Tundra Limited
    I have a 2007 Tundra 5.1L V8 4 wheel drive with 156,000 mi. Transmission appears to be slipping. Can this transmission be rebuilt or will I have to purchase a new transmission? Was told a new one would cost about $4500. Is that reasonable or can it be repaired.
  2. Dec 8, 2016 at 2:23 PM
    Have you had it serviced?
  3. Dec 8, 2016 at 2:25 PM
    Mike Tread lightly.
    south carolina
    Transmission can be rebuilt by a shop the other option is too get a remanufactured one.. most remanufactured ones (good ones) come with a warranty on it..
  4. Dec 8, 2016 at 2:30 PM
    tigerman
    I took it to a shop and was told it needed to be replaced. Don't believe they opened it to check. Told me it couldn't be rebuilt. Not sure how they determined this. Can you get a reading that tells what the problem is?
  5. Dec 8, 2016 at 3:26 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  6. Dec 8, 2016 at 3:45 PM
    cdkenne
    cdkenne Toyota Master Technician
    Corey
    KS
    2002 Tundra SR5 TRD Offroad
    285/70R17, '15 4Run Trail Wheels, Westin Shopping Cart Basher, SnapOn license plate cover that adds >50 HP
    In dealership, we do not rebuild automatic transmissions. That's not to say they can't be rebuilt, but I had a Jasper reman transmission in my Odyssey and it lasted 6 months longer than the warranty (3 years) before catastrophic failure.
    With any World Standard transmissions, I start with draining the fluid and setting the level via Techstream and the check hole. I have seen this clear up many shift quality and slipping issues. If the fluid level is not correct or there are any contaminants in the fluid it can cause all kinds of problems.
    That being said, we don't replace many Toyota automatic transmissions. When we do, we almost always use Toyota remans.
    Do you have any explanation as to why they said it needs replaced?
