2007 Power Mirrors Not Operating
Discussion in '2nd Gen Tundras (2007-2013)' started by ARayT, Jun 11, 2020.
  1. Jun 11, 2020 at 1:42 PM
    ARayT
    ARayT [OP] New Member
    GEORGIA
    2007 Tundra XSP
    Anybody had issue with power mirrors? looked for fuse, no find. Neither side works. Any help appreciated.
    Thanks Ray
  2. Jun 13, 2020 at 12:58 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Check your switch see if its plugged in , if so check for in power , if it has power going to it , check that the power is going out when the switch is activated. If no power out . The switch is bad.
    If their is no power going to the switch then its down the path before the switch. Ill search my factory service manual for some info.
  3. Jun 13, 2020 at 1:11 PM
    NueveTundra
    Planet Earth
    their is also a power mirror ECU in the drivers door to check .
    ill continue digging seeing what else i can i find
  4. Jun 13, 2020 at 1:33 PM
    NueveTundra
    Planet Earth
    here you go this is the chart for testing the switch . an what the book calls for . since its both mirrors i doubt both went bad at the same time. so ill spare you the mirror test pics. if you do end up needed them hit me up...
    but this should solve your issue @ARayT
  5. Jun 13, 2020 at 2:36 PM
    ARayT
    GEORGIA
    2007 Tundra XSP
    Thanks NueveTundra for the info. I kinda thought the same not common that both failed at same time, probably power issue. I did not realize there was an ECU. I had driver door cover off a few days ago changing the door lock motor hope I did not mess it up. Thanks Again I start digging.
    rt
  6. Jun 13, 2020 at 4:41 PM
    ARayT
    GEORGIA
    2007 Tundra XSP
    Thanks NueveTundra, can't believe it the dang thing was unpluged. Appreciate the help!!
  7. Jun 13, 2020 at 4:46 PM
    TXTundra2722
    2015 Black Tundra
    And another problem solved due to this awesome forum.......I guess @NueveTundra helped just a tad too!
    :D
  8. Jun 13, 2020 at 4:53 PM
    ARayT
    GEORGIA
    2007 Tundra XSP
    Yep huge help, thanks NueveTundra. Lucky it was an easy fix but NueveTundra sent additional if I had needed it. Awesome is the right word! Its has saved many in time, material and labor.
