2007 HID conversion won’t fit factory harness
Discussion in '2nd Gen Tundras (2007-2013)' started by TundraTRD08, Jul 16, 2022.
  1. Jul 16, 2022 at 4:11 PM
    TundraTRD08
    TundraTRD08 [OP] Somehow I fit 37s on a level
    Wesley
    08 Super White TRD Off-Road on 37s
    3.5' RC lifted struts with RC UCA Alcan rear leaf spring upgrade with 300lbs added weight+1" lift built in. Adjustable Alcan Shackles set to add an extra inch which equals to a 2" lift in the rear. 37” Maxxis RAZR M/Ts with 1.5” spacers 8” BAMuffler Tuned by Bully Dog Tuner
    I just got some new housings that have a projector for low beam only, as well as hid lights for them. I have a relay harness, the ballasts, bulbs and all. I’m at the point where everything is hooked up except the relay harness to the factory one. Is there some sort of conversion kit from the connectors that are on the relay harness to the factory ones?
    Danny3737 likes this.
  2. Jul 16, 2022 at 7:01 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    You can get a relay harness that connects to the factory headlight harness from theretrofitsource.com.
    TundraTRD08[OP] likes this.
  3. Jul 16, 2022 at 8:09 PM
    TundraTRD08
    Wesley
    Thanks for shooting me in the right direction, but I’m not real sure which option I need to go with. Like I said, they’re for the low beams. Everything fits except the plug that goes into the factory harness. Again, thanks.
  4. Jul 16, 2022 at 8:16 PM
    BlueRibbon4x4
    Geno
    Ok check it out. You can make your own with this plug. Is it the triple plug? I’m unfamiliar with the 2nd Gen headlights. If it is, this is it. Wire up as necessary after using a test light to check your low beams and ground. You only need to use one side to trigger the relay.
    H4 9003 HB2 Female&Male Wire Wiring Harness Sockets for 4"x6" 7"x6" 5"x7" inch Sealed Beam Car Truck Headlights Pickup Heavy Duty Headlamp 2set https://www.amazon.com/dp/B098JW7VZX
  5. Jul 21, 2022 at 9:02 AM
    TundraTRD08
    Wesley
    These are not the same, unfortunately. It is just two prongs that fit into a little oval shape. My problem was that the prongs were too far apart on the relay harness. I am doing away with these headlights and looking to do AlphaRex Pro Series housings with an HID Conversion. Hopefully it is a little more plug n play. Do you have any info on this?
  6. Jul 21, 2022 at 3:42 PM
    BlueRibbon4x4
    Geno
    On that specific kit, I don’t have any info. But any HID kit will require pretty much what you have already, all tou need is the plug to go to your existing headlight plug. An option is to tap into the existing wires, but it’s just as easy to get the correct plug and wire it clean.
