2007 2WD No D/S Grease Fitting?
Discussion in '2nd Gen Tundras (2007-2013)' started by TexasGuyTX, Jan 24, 2024.
  1. Jan 24, 2024 at 5:05 PM
    TexasGuyTX
    TexasGuyTX [OP] New Member
    Ryan
    2007 SR5 Super White
    PRO BOX w/ RF Mono Amp Limited 20" Wheels HID's on Low Beams Tip Delete Before Axle
    I got the clunk what are yall doing for remedies besides pulling the shaft and replacing... I looked at them today not a crazy amount of play I would worry about just annoying because I know it is there
  2. Jan 24, 2024 at 5:07 PM
    Bad U joint clunking?
  3. Jan 24, 2024 at 5:15 PM
    TexasGuyTX
    Ryan
    it points that way everything else with the truck is in spec... its cleary when everything is loading and unloading in the driveline.. i guess I will have to pull the shaft since I cant get it todo anything with a pry bar
    very disappointed in toyota with this with us not being able to service.. this truck has been in the family since 09 (11k miles) I remember it clunking when I drove it a couple years ago but not that bad just real slight but it wasnt mine and my father wasnt worried about it so I left it be..
  4. Jan 24, 2024 at 6:57 PM
    Canman
    Canman New Member
    2007 Crewmax Limited
    Does your driveshaft have a carrier bearing? We had a clunking on our 07 Crewmax 5.7 4x4 and it turned out to be the carrier bearing for the driveshaft.
  5. Jan 24, 2024 at 7:43 PM
    TexasGuyTX
    Ryan
    I didnt have the truck jacked up so space was slightly limited today lol.. my 2 post lifts seal is blown out atm so no air time :( I was not looking in the middle for a carrier bearing just the drive shaft U joints I guess I need to look again at it
    When was it clunking btw? drive/reverse at from park or stopping and going?
  6. Jan 25, 2024 at 3:38 AM
    Canman
    Canman New Member
    Mostly from accelerating from a stop IIRC. The actual cause of the failure was a result of the PO installing some HD rear leaf springs incorrectly (wrong sides) which pushed the entire rear axle back. This in turn reduced engagement on the splines which caused the driveshaft to wobble which then caused the bearing failure. Incredible how stupid folks are, and the guy/PO was a GMC mechanic.
    des2mtn likes this.
