2006 Tundra worth?
Discussion in '1st Gen Tundras (2000-2006)' started by kidked888, Jan 4, 2021.
  1. Jan 4, 2021 at 6:50 AM
    kidked888
    kidked888 [OP] New Member
    Kansas
    2004 Tundra Double Cab 2WD
    Have the seller agreeing to 14k for a 2006 double cab with 96k miles and 4WD. Very good shape overall and timing belt recently changed at 89k. Should I pull the plug and snag it before someone else does? His original asking price was 15.5k
    Stuck in the '00s and MTRock like this.
  2. Jan 4, 2021 at 7:12 AM
    BTBAKER
    BTBAKER DIFFERENT NAME. SAME JUNK.
    Brad
    Castle Rock
    2023 Ram Rebel
    What’s the KBB value on it? If everything checks out on it and it’s what you’re looking for then yes, pull the trigger.
  3. Jan 4, 2021 at 7:18 AM
    kidked888
    Kansas
    top end KBB is 13.5-13.8k
  4. Jan 4, 2021 at 7:20 AM
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    Looks like a good truck, if it's worth 14k to you, go for it. Some have paid more, some have paid less. Clean non-rusty 4wd Dbl cabs with less than 100k miles are unicorns. This one has obviously not been off-roaded either.
  5. Jan 4, 2021 at 7:30 AM
    BTBAKER
    Brad
    Castle Rock
    2023 Ram Rebel
    It’s not to far off this mark and it’s low mileage. Carfax check out?
  6. Jan 4, 2021 at 7:35 AM
    kidked888
    Kansas
    No, have not run a carfax on it. Probably should spend the $40 just to be safe
  7. Jan 4, 2021 at 7:35 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Don't put much faith in kbb. They've never been very accurate and during the last year prices of used trucks has gone high.
    What state is this in? How does the undercarriage look?
  8. Jan 4, 2021 at 7:36 AM
    kidked888
    Kansas
    Truck is in Kansas. Frame looks good. Very slight rust (nothing serious) and previous owner put some sort of coat to prevent any further
  9. Jan 4, 2021 at 7:39 AM
    FirstGenVol
    FirstGenVol Brake Czar
    East TN
    2002 AC
    That's actually not always a good thing. Some of the rubberized undercoatings actually make things worse. I would really spend 20-30 minutes up under the frame with a flashlight. We've had numerus members buy a 1st gen without really inspecting the frame only to realize the truck is a goner. If the frame is as nice as you say, then go for it. I would assume Kansas gets a lot of salt so I would be cautious.
    flyfisher and arctictundra8577 like this.
  10. Jan 4, 2021 at 7:40 AM
    Pics of the frame would be helpful in determining the rust factor
  11. Jan 4, 2021 at 7:40 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I would say go have a look. Take a screw driver and if you see rust or strange textures on the frame give them a poke. If that looks okay, should be a good buy.
  12. Jan 4, 2021 at 7:43 AM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    05 DC SR5 / 06 SEQUOIA LTD
    Vehicles are worth whatever you are willing to pay. I think KBB typically undervalues toyota 4x4s, especially in regions where they are very popular.
    Will have a hard time finding a tundra DC with that low of mileage and appears to be in great shape.
    des2mtn likes this.
  13. Jan 4, 2021 at 8:47 AM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    If there is no frame rust and it's got a clean history, I'd snag it.
    $14K is often a 'Down Payment' on some of todays new trucks.
  14. Jan 4, 2021 at 9:07 AM
    Yotatrucks7
    Yotatrucks7 New Member
    2017 DC Tundra
    As mentioned above, I'd check the Carfax and/or Autocheck history. As long as the frame just has surface rust, I'd say that's a buy. KBB can be a helpful guide, but cars are generally worth what people will pay for them. Market conditions have an impact as well as supply and demand. These trucks are hard to find in that kind of shape with those miles. I buy cars for CarMax for a living in Colorado and that truck would be worth quite a bit more out here, honestly.
    BTBAKER likes this.
  15. Jan 4, 2021 at 11:24 AM
    kidked888
    Kansas
    Met with the owner again and got some pics of the frame. Please let me know what you think. I told him this was the make or break on me purchasing the truck.
  16. Jan 4, 2021 at 11:40 AM
    Yotatrucks7
    2017 DC Tundra
    Looks like a good amount of rust. Someone appears to have attempted spray painting it in some of the photos. Personally, I'd stay away from that one. Not the worst I've seen but certainly not great in my opinion.
    If the "coating" they were talking about is just the spray paint(or whatever it is) sprayed over rust, that really doesn't do much of anything. You gotta get to it before the rust starts, obviously.
    flyfisher likes this.
  17. Jan 4, 2021 at 11:45 AM
    kidked888
    Kansas
    Do you know what is gong on in the first picture attached with the yellow highlight around it. Im not a mechanic by any means, but to me looks like to different supports on the frame are expanding? Looks like rust or some sort of build-up in between
  18. Jan 4, 2021 at 11:57 AM
    Yotatrucks7
    2017 DC Tundra
    I saw that. It appears in the third to the last photo as well. Without looking in person it's hard to tell...but it appears to be either some really odd damage, or whatever they use on the roads in Kansas has caused some crazy reaction to force those sections of frame to separate like that.
  19. Jan 4, 2021 at 12:19 PM
    737fixer
    737fixer New Member
    Price is slightly high for the truck in "Very Good" condition. This truck looks clean but your closer inspection reveals the "very good" is way off. As the other person pointed out the rust is really not an issue but the hiding of it is. Once a seller has resorted to hiding problems you have not idea what else has been covered up. Run away.
    Side note. Just cause I'm bored I decided to run the KBB on the Chevy, Ford, and Dodge even though at the time they were significantly higher priced, higher end, and larger. I gave an effort to keep things equal even though its hard cause the other brands offered much more and the Chevy in the crewcab was also heavy duty. Funny how even though "were just as good as Toyota" your resale even to a truck not even close to your specs is embarrassing. I sold my 2005 Tundra in 2019 before buying my 3rd Gen and it had over 210,000 miles and still got almost 9K. New in 2005 it was $26,500 as we still have the sticker. 66% loss in 14 years and 210,000+ miles. Not sure the Ford with 210 total miles would get that. Resale value is the ultimate decider in a vehicles worth and Cooter's Dodge (Fiat) Ram may be just outstanding at $73,000 dollars but at 200,000 miles in 2034 it won't be worth its price in sheetmetal.
    kidked888[OP] likes this.
  20. Jan 4, 2021 at 12:50 PM
    BTBAKER
    Brad
    Castle Rock
    2023 Ram Rebel
    There’s some spots in those pics that would make me high tail it.
  21. Jan 4, 2021 at 12:52 PM
    BTBAKER
    Brad
    Castle Rock
    2023 Ram Rebel
    This shot IMO is a runner for sure. I vote you bail and save yourself the headache.
  22. Jan 4, 2021 at 12:53 PM
    kidked888
    Kansas
    I think I am going to have to pass on the truck. For the price I wouldn’t be able to sleep at night. Can you elaborate a little more on exactly what you marked in the picture?
    Nevermind I looked at the full picture. Looks completely rusted though. Completely missed that
    Yotatrucks7 likes this.
  23. Jan 4, 2021 at 12:58 PM
    BTBAKER
    Brad
    Castle Rock
    2023 Ram Rebel
    That’s what it looks like to me.
  24. Jan 4, 2021 at 1:15 PM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
  25. Jan 4, 2021 at 2:31 PM
    FirstGenVol
    East TN
    2002 AC
    It's not damage. It's actually very common. That area of the frame "overlaps". I say that in quotes because it's really a brace they put over the frame for support. Water/salt gets behind it and causes it to delaminate. My truck is from the south and still did it, though not nearly as bad. I test drove a 06 DC today and it had the same issue.
    Yotatrucks7[QUOTED] likes this.
  26. Jan 4, 2021 at 2:50 PM
    Professional Hand Model
    Hand Protectors
