2006 tpms bypass, which wire?
Discussion in '1st Gen Tundras (2000-2006)' started by Bevoga, Jun 7, 2020.
  1. Jun 7, 2020 at 8:25 AM
    Bevoga
    Bevoga [OP] New Member
    Troy
    2006 Tundra single cab V6
    I found the wiring for the TPMS to bypass it. I have the pink/gray wire with the black stripe, but there is not another pink/gray wire. Is it the all pink wire i ground? Anyone happen to know which wire i ground to by pass the tpms for good? Thanks for the help!
  2. Jun 7, 2020 at 10:49 AM
    sflips
    sflips New Member
    Middle Tn.
    2006 DC XSP
    @noahtibbetts has an 06, he grounded the solid pink. Page 4 on Disable TPMS thread. He had the pink-silver-black wire and a solid pink wire.
  3. Jun 7, 2020 at 12:28 PM
    Bevoga
    Troy
    So to follow up. I cut the solid pink wire and ran it to the nearest ground. The cut portion from the plug I put a connector on (just in case) and just taped it off. Shrink wrapped the connections and viola, never a tpms light again! Thanks to sflips and noahtibbetts for your help!
    sflips likes this.
  4. Jun 7, 2020 at 7:14 PM
    JMH
    JMH New Member
    Okay, I'm confused. Some say for the 2006 Tundra ground the solid pink wire, and others say the pink/silver wire to ground. I haven't tried doing this yet. So, if I see a solid pink wire that's the one to ground. If I don't see a solid pink wire, ground the pink wire with silver bands?
  5. Jun 9, 2020 at 1:19 PM
    JMH
    JMH New Member
    Nobody cares to clear this up for me?
  6. Jun 10, 2020 at 4:50 PM
    JMH
    JMH New Member
    191 views and nobody helps with my question. Nice.
  7. Jun 11, 2020 at 5:50 AM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Good god you sound like a spoiled child. These forums aren’t your personal Alexa.
    baraynavab, POC, dbittle and 4 others like this.
  8. Jun 11, 2020 at 8:52 AM
    JMH
    JMH New Member
    Now there's a snarky remark. You don't like my remarks? It's called 'ignore'. Or maybe try to contribute and be helpful. But obviously you can't.
    Seems like Tundras.com isn't a friendly place. Don't know if I care to be a member with rude members.
    Have a great day.
  9. Jun 11, 2020 at 9:34 AM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    Since you are a veteran you get a redo from me, but please go back and read your posts and try to understand how you are coming off. This forum is full of tons of good people who share the love of 1st gen Tundras and just want to help others.
    Your question is correct. Cut the solid pink or pink with silver bands.
  10. Jun 11, 2020 at 10:13 AM
    JMH
    JMH New Member
    Seth419: I may at times come across angry or post comments that come from frustration (and some anger). Was in Vietnam 68-69 and came in contact with Agent Orange. In 2013 I had a massive heart attack caused by Agent Orange. Vietnam was going to get me one way or the other. My heart stopped beating for over 45 minutes (2013) starving my mind and body of good 'ol H20 while everyone in the hospital gave me Cardiac Arrest and 33 shocks. Doctors didn't think I'd make it and if so my mind and organs would be in bad shape, which they are, but not as bad as they thought. The doctors and all the rest saved my life, which they weren't sure I'd live through it. So sometimes I say things that could be said bitter. But every since VN I've not been the same person that I was before - kind and full of fun. I still deal with some anxiety and paranoia with a little anger mixed in. Have had that monkey on my back for a long time now. I've said enough. I'll try to do better if I'm still welcomed. Y'all have a great day.
    Sgt E5 110th Trans Co. Vietnam September 1968 - August 1969.
  11. Jun 11, 2020 at 10:41 AM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    I completely understand and welcome you to the forum!!!!! Thank you for your service!!
    POC and FrenchToasty like this.
  12. Jun 11, 2020 at 1:45 PM
    JMH
    JMH New Member
    Thank you, Seth419
  13. Jun 11, 2020 at 8:10 PM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    No harm, no foul. Lots of subtleties are lost to text. I honestly figured you were some 16 year old kid demanding help without doing any leg work and for that I apologize.
  14. Jun 11, 2020 at 9:54 PM
    JMH
    JMH New Member
    That's cool. Thank you.
  15. Jun 11, 2020 at 9:57 PM
    JMH
    JMH New Member
    BTW, not H2O, I meant oxygen. My thoughts wondering around I guess.
  16. Jan 29, 2021 at 10:09 AM
    tundrainsc
    tundrainsc Happy Tundra 1st Gen
    06 Limited 4.7 2WD
    Not knowing for sure which wire to cut/ground, i simply put small piece of black electrical tape over the obnoxious flashing light. On my 2006 the light is over in the right bottom corner of the display and not noticeable anyway unless you are looking for it. Little afraid creating other electrical problems by cutting and grounding wires when avoidable. When I get new tires will consider whether i want to replace the sensors. RE: buying sensors. I got burned a few years ago paying $85 bucks on ebay and $20 bucks install for set of sensors for my Deville that never worked with efforts by tire shops and the dealer to reset. If I do get new sensors, this time i will pay the extra and buy them locally along with the tires, so I can make sure they work.
