2006 toyota tundra sr5 4.0 v6 starting problems
Discussion in 'General Tundra Discussion' started by charris4790, Jan 5, 2023.
  1. Jan 5, 2023 at 2:52 PM
    charris4790
    charris4790 [OP] New Member
    cody
    SO i got a 2006 Toyota tundra sr5 4.0 v6 truck never really had problems until i moved to Montana with it .. only when it starts to get really cold truck has starting problems or staying started .. i replaced battery , replaced alternator 2 years ago thought maybe that was the problem decided to take it to Oreilly to get tested and they told me it tested good , they were telling me probley a bad connection somewhere would that possible be it
    Replaced serptine belt , battery December 2022
    starter replaced august 2020
    this really frustrating could anyone help
  2. Jan 5, 2023 at 3:15 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Maybe have the stealership flash the ecu for altitude?? Stealership advised me of this when I took it in for a TSB..
    I got mt 5.7 flashed for higher altitude in Reno, NV purchased mine in LA... Didn't have starting issues, but may be an air/fuel ratio issue... Assuming no electrical damage has been done...
    charris4790[OP] likes this.
  3. Jan 5, 2023 at 3:19 PM
    Mr Badwrench
    Mr Badwrench New Member
    Is it lugging down or chopping out when you are able to get it started?
  4. Jan 5, 2023 at 3:29 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Should post a thread in the first gen section and you'll get more bites.
    https://www.tundras.com/forums/1st-gen-tundras-2000-2006.2/
  5. Jan 5, 2023 at 3:41 PM
    gsrocks
    gsrocks New Member
    Bad battery cable or ground.
