2006 Toyota Tundra double cab 2wd leaning to the right
Discussion in '1st Gen Tundras (2000-2006)' started by Mflores, Jan 21, 2020.
  1. Jan 21, 2020 at 5:32 PM
    Mflores
    Mflores [OP] New Member
    Marc FloresPadilla
    Toyota Tundra Xsp
    Lifted
    Hi, guys... I am back in forum with another question. I have my 2006 leaning to the right side (passenger). It’s my first time looking at it and spotting it. It has been lifted since I bought it with 20in rims and Toyota Tundra rancho quick lift leveling struts and shocks. I took the measurements today and it is by far 1” lower on the rights side. I took the measurements from ground to the back side of bed from both side. Any suggestions on what can it be?
  2. Jan 21, 2020 at 7:31 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Coils commonly sag. Usually a vehicle gets "driver lean" because of the gas tank weight sometimes being on the driver side and springs are matched left to right vs balanced to the vehicle's specific weight distribution, what happens when coil/struts are shared among vehicles, oh well.
    Replacing the springs would be the optimal solution though there are other less expensive ways to try to create a more level ride yet many don't like those 'short cut' attempts. Luck.
  3. Jan 21, 2020 at 7:36 PM
    Mflores
    Marc FloresPadilla
    Toyota Tundra Xsp
    Lifted
    Thanks, for the info... but if it where not the spring. What other possible problem could it be? It is leaning from the back part passenger side 1” lower. Also the gas tank is on the right.
  4. Jan 21, 2020 at 7:39 PM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Lift, Rims, Bigger Tires, Nerf Bars, Black Out Emblems
    Sounds like you got a weak/defective spring when you installed your lift. Warranty it or replace with a better manufacturer.
  5. Jan 21, 2020 at 7:41 PM
    Mflores
    Marc FloresPadilla
    Toyota Tundra Xsp
    Lifted
    That’s the other thing if it would be the strut in the back. I bought it with the lift. That’s what I do not know if it was like that since I bought it or this is a new problem.
  6. Jan 21, 2020 at 7:47 PM
    Johnsonman
    Austin
    Sequoia
    Well yeah more common is spring but could be strut/shock, worn bushings probably wouldn't affect things so much, super low air tire pressure - nah, so much rust on rear suspension components and/or frame such that something is sagging/broken - nah....
  7. Jan 21, 2020 at 8:32 PM
    Mflores
    Marc FloresPadilla
    Toyota Tundra Xsp
    Lifted
    Sorry to ask, when you say “so much rust on suspension components or frame such something is sagging and broken”. What do you mean in terms of sagging/broken. Let me be more specific toward my question. Is their any other major component that can lead my truck to be 1” lower from one side than just the strut itself?
  8. Jan 21, 2020 at 10:12 PM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    Which corner is lower, driver front, driver rear, passenger front or passenger rear? Measure from hub center to fender. You say that you have the Rancho Quick Lift which I believe comes with springs.
    If the it’s the front, OEM Toyota springs have a left and right to compensate for one side being heavier. Either the Rancho’s are both the same spring rate, or they are swapped side to side.
    If the rear is off, you need to inspect the springs and bushings. Maybe the rear springs are bad.
    FYI, when referring to right & left, it’s from sitting in the driver seat. Driver=left, passenger=right
  9. Jan 22, 2020 at 3:06 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    My vote is that one side has a more worn strut bushing, you're springs are just funny, or you have something else worn like sway bar end link bushings that are putting tension on one side at ride height.
  10. Jan 22, 2020 at 4:40 AM
    Professional Hand Model
    Hand Protectors
    How much are we lifted?
  11. Jan 22, 2020 at 7:06 PM
    Mflores
    Marc FloresPadilla
    Toyota Tundra Xsp
    Lifted
    The only thing right know that the truck has for its lift it just the rancho spring that I mentioned. I wouldn’t know how tall would it be... like I said the only side that I see lower is passenger (right) rear (bed). The thing about it is that I can notice it.
  12. Jan 23, 2020 at 3:33 AM
    BubbaW
    BubbaW Been Real
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Care to throw up some pics....perhaps one from rear, leaf springs on passenger rear and perhaps a passenger side view.
  13. Jan 24, 2020 at 4:09 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    Shocks have nothing to do with the leveling of a vehicle. It's the coils on the struts or springs loss tension. You would have to have some serious bushing rot to make that drop, I doubt that, but you can look and see that for yourself.
