2006 SR5 alternator
Discussion in '1st Gen Tundras (2000-2006)' started by shaw0531, Jun 26, 2017.
  1. Jun 26, 2017 at 7:31 PM
    shaw0531
    shaw0531 [OP] New Member
    Jake
    2006 Spectra Blue Mica Tundra SR5 2WD DC
    Thinking my alternator may be heading out. Drove home from the store and battery light came on, checked volts with my ultra gauge and I'm only getting 11.5-11.80 volts while running. There's a slight whine as well that adjusts with the rpm. Not sure if a bearing is seized up or what's going on but my guess is alternator. What brand does everybody use when they replace theirs? Duralast, denso?
    Thanks,
    Jake
  2. Jun 26, 2017 at 7:54 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
  3. Jun 26, 2017 at 8:16 PM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    I just get mine "rebuilt" from a local Alternator repair shop. This is usually the most cost effective solution and in my past experience the BEST solution. Usually the Stator, diodes or rectifier get worn out. However you are mentioning a slight squeek, the issue may also be the bearing going bad or the pulley going bad.
  4. Jun 27, 2017 at 4:17 PM
    shaw0531
    Jake
    Mind me asking how cost effective? I'm seeing new and reman ones for 160-220ish
  5. Jun 27, 2017 at 4:18 PM
    shaw0531
    Jake
    Also what amperage would you guys recommend or what is stock? The options go from 80amps to 130amps
  6. Jun 27, 2017 at 5:58 PM
    kenomouth64
    Tetrus
    Rebuild is usually around $40-$60, depending on what is wrong with it. Typically the technician will take it apart, let you know there suggestion. Usually they do not charge for this.
    Just depends on how much "Charging Power" you want. It is always helpful for me to think of Amperage as "electrical pressure". If that makes sense to you, lol.
