2006 double cab fuel pump no power
Discussion in '1st Gen Tundras (2000-2006)' started by Bagaboo, Dec 27, 2018.
  1. Dec 27, 2018 at 3:45 PM
    Bagaboo
    Bagaboo [OP] New Member
    i bought a 2006 tundra double cab with 4.7 engine not running with 160xxx miles. It had a check engine light for P0340 camshaft position sensor circuit and P0345 camshaft position sensor circuit. The sensor wires were crimped between 2 metals so I changed it out with a new sensor from Toyota and still don’t start. I also replaced the starter with a oem starter from Toyota and changed the fuel pump thinking it don’t work but doesn’t buzz but realized no power going to fuel pump. I need help and hoping someone ran across this problem. I read the Toyota Hanes book and says the crankshaft sensor send a signal to the relay to give power to the fuel pump. Does that sound correct? I don’t want to spend any more money that I don’t have to.
  2. Dec 27, 2018 at 5:37 PM
    Adriver71x
    Adriver71x New Member
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    Welcome from Ct. Did you check all the wires where they were crimped? There could be a broken wire in side the shielding you can't see. Test the wires on both sides of the crimped area
  3. Dec 27, 2018 at 6:39 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    The pump will only get power for about 2 seconds when the key is turned. If the engine isn't started the voltage will stop.
    You can check the wiring easily enough by jumping the pump relay.
    I'll get you a wiring diagram and troubleshooting chart tomorrow.
  4. Dec 28, 2018 at 4:04 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    Here's a couple to start with.
    • fpc.pdf
      File size:
      57.2 KB
      91
    • fpr.pdf
      File size:
      9.2 KB
      51
  5. Dec 28, 2018 at 7:19 AM
    Bagaboo
    Where is the fuel pump resistor located?
  6. Dec 28, 2018 at 8:17 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    Under the hood, passenger side behind the airbox.
    Filthyphil likes this.
  7. Sep 28, 2022 at 10:39 AM
    J. R.
    J. R. New Member
    Jose
    06 Tundra SR5
    I'm curious! What is listed on the problems symptoms table on Dl-452?
  8. Sep 28, 2022 at 11:21 AM
    shifty` Got patience on my neck like a cold, cold knife
    I'm guessing the OP's issue was probably crankshaft position sensor wiring failure. Pump won't fire up unless CPS is sending a valid signal. Too bad this post is years old.
    Not sure this will help, but here's a screencap. It doesn't mention what row of the table is the one, you'll need to scan and figure it out. :D
  9. Sep 28, 2022 at 11:41 AM
    J. R.
    J. R. New Member
    Jose
    06 Tundra SR5
    Thank you Shifty, It seems crank but no start leads to Fuelpump Control Circuit. So far, I appear to have a shorted Fuel Pump Resistor. Once I receive the new one, I will update this post.
    Mbd5033 likes this.
  10. Sep 28, 2022 at 11:54 AM
    I dunno. Can be the crankshaft position sensor like here. OR the resistor. Or fuel pump relay. Or chewed fuel pump wires, which happens more than you'd think.
    Really helps to know if you've got any fuel pressure getting to the fuel rail. Just know, the fuel pump won't actuate with the key in the ON position, only when cranking, so measure fuel pressure while cranking.
    Here's a good video on fuel diagnostics:
    Another great video on starting diagnostics, maybe not as applicable:
  11. Oct 28, 2022 at 5:26 PM
    J. R.
    J. R. New Member
    Jose
    06 Tundra SR5
    My start relay is not getting any power. Do you know where the connector joining wire harness IJ4 is located? I found IJ1, 2, and 3. But I can't find IJ4. Please advise.
  12. Oct 28, 2022 at 6:37 PM
  13. Oct 29, 2022 at 4:13 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    A resistor is a short and should have a set resistance when checking with a VOM(volt ohm meter)
    Supposed to be next to IJ2/3 according to 2006 FSM
    Fuel circuit from 06 EWD....
    shifty` likes this.
  14. Oct 29, 2022 at 11:49 AM
    J. R.
    J. R. New Member
    Jose
    06 Tundra SR5
    Thank you! So, practically IJ1 on the 05 Tundra, is IJ4 on the 06 Tundra. The reason I need clarification is that my starter relay is not energizing to provide power to the starter. Therefore, I need to backtrack to find the open circuit.
  15. Oct 29, 2022 at 1:12 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Yes
    Not sure if this will help....
  16. Oct 29, 2022 at 1:39 PM
    J. R.
    J. R. New Member
    Jose
    06 Tundra SR5
    Thanks, how difficult is it to access IJ4 connector?
  17. Oct 29, 2022 at 3:59 PM
    IJ4 is a 26-pin connector also, if it helps...
  18. Oct 29, 2022 at 5:08 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    It’s in the cowl panel area where ECU is which means glove box should have to come out.
  19. Oct 30, 2022 at 11:47 AM
    J. R.
    J. R. New Member
    Jose
    06 Tundra SR5
    The only connector that I see across/above IJ2 & IJ3 seems to be a ground connector. Is that IJ4? The diagram shows a male and female connection. Do you have any visual aid (photo) that will show what it looks like? Unless it is behind heat exchanger, I do not readily see it.
  20. Apr 27, 2023 at 7:25 AM
    noahrexion
    noahrexion New Member
    Washington
    2005 4WD DC
    Any follow up?
