2005 tundra ticking engine compartment
Discussion in 'General Tundra Discussion' started by GUSORD, Apr 28, 2021.
  1. Apr 28, 2021 at 6:17 PM
    GUSORD
    GUSORD [OP] New Member
    When I start up cold there is a loud ticking noise and the oil pressure goes up but after a while the ticking noise goes way down and the oil pressure evens out to normal pressure.
  2. Apr 28, 2021 at 6:37 PM
    brobert225
    brobert225 Firm grasp of the obvious
    Your exhaust manifolds are likely cracked. Not a huge issue but common.
    des2mtn likes this.
  3. Apr 28, 2021 at 6:50 PM
    GUSORD
    Do they find this problem exhaust manifold cracked by using a diagnostic machine ?
  4. Apr 29, 2021 at 9:36 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    could also be that you need an oil change. Ticking can come from many things- lifters, exhaust, accessory pulleys and belts. Suggest you see if you can isolate where the noise is coming from.
  5. Apr 29, 2021 at 1:11 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
  6. Apr 29, 2021 at 1:18 PM
    des2mtn
    SW
    Tonto cover
    peanut likes this.
