2005 tundra 4.7 liter v8
Discussion in '1st Gen Tundras (2000-2006)' started by Jacobmetroid, May 15, 2017.
4.7 liter v8 or newer 5.7 v8
Poll closed May 22, 2017.
  1. 4.7
    66.7%
  2. 5.7
    33.3%
  1. May 15, 2017 at 10:12 PM
    Jacobmetroid
    Jacobmetroid [OP] New Member
    Jacob
    2005 tundra
    I am curious how long the engines last? I've heard good things and am looking at a 2005 with 227k on it. I haven't check the service records yet but looks super clean. It drives very nice steering is not sloppy and has very responsive throttle more than I was expecting for a 4.7. If all the records come back good would any of you hesitate? I KBB the truck based on trim and options it's worth about 8-8.5k dealer wants 6k it's been sitting there awhile. The interior looks loved I can only hope the same is true with engine. Any common issues with this year or issue that you think I should look out for? Thanks in advance. And btw how many miles on your 4.7 V8 and what have you done maintenance wise for it in that time?
  2. May 15, 2017 at 10:31 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    A guy recently traded in his 1 million mile Tundra with the 4.7.
    kenomouth64 and Jacobmetroid[OP] like this.
  3. May 15, 2017 at 10:34 PM
    Jacobmetroid
    Jacob
    2005 tundra
    Wow that's amazing do you know what he had done to it in that time or no?
  4. May 15, 2017 at 10:46 PM
    Joeshaker
    Joeshaker New Member
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bilstein 6112/5160 trd sway bar and ride rite bags. Black and burnt orange wet okole seat covers.
    I sold my 2000 limited access cab with 187k for $10000 last year. Probably could have gotten more! $6000 sounds good even with those miles. 4.7 is a good motor all mine ever needed was the normal stuff. Timing belt, water pump and pulleys and spark plugs.
  5. May 15, 2017 at 10:54 PM
    Jacobmetroid
    Jacob
    2005 tundra
    $10k that's awesome. Thanks for the help.
  6. May 15, 2017 at 10:55 PM
    Mike Tread lightly.
    south carolina
    2005
    When was the timing belt and water pump changed last? If it over 5 years or 90,000 miles replace it.
    Only thing bad is the stupid air pump system they will fail... If it does bypass it and you are back to normal.
    I'm not going to lie. The 4.7 does have cast rods. Now if you put the engine on excessive loads or have a heavy foot it's not the engine for you. Rods will break.. If you rebuild the engine with forge rods the engine is a beast( doing mine soon).
    I have a 2003 same engine minus the air pump and vvti. Mine is a 4 speed where yours is a 5.
  7. May 15, 2017 at 10:57 PM
    Jacobmetroid
    Jacob
    2005 tundra
    How much do forged rods cost with labor as I would get mine done at shop? And BTW no towing will be done with it but may have been used to tow things in the past as it has that tow package optioned on it.
  8. May 15, 2017 at 11:02 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Mine had a funky knock when it was super cold out. I had just done all new brakes again! And done the rear wheel bearings and one axle. Not the original rear end. I also had replaced the transfer case a few years back. You didn't say if the one you're looking at is 4wd, access cab, double cab? Those things make a big difference in value.
  9. May 15, 2017 at 11:04 PM
    Jacobmetroid
    Jacob
    2005 tundra
    It's a 4WD access cab with SR5 trim
  10. May 16, 2017 at 8:32 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Yeah, sounds like a good deal. Get them to start it up cold for you and check for smoke and any weird noises. Try 4wd high and low. Ask them if you can take it to your mechanic. If they say no there could be something wrong with it.
