2005 Stock front shock and strut replacement
Discussion in 'Suspension' started by jpcolorado, Jul 26, 2018.
  1. Jul 26, 2018 at 11:16 AM
    jpcolorado
    jpcolorado [OP] New Member
    Hello - I have a 2005 Toyota Sequoia SR5 with 195k miles on it and need to replace the front shocks and struts. I wanted to see if anyone has a good suggestion on all-in one strut and shock kits. The stealership wants $182 for a shock, $251 for the spring and $196 for the upper components. Crazy! I don't have a spring compressor so I was hoping that there would be a good strut and shock option.
    Thanks - Jeff
  2. Jul 26, 2018 at 11:40 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    There's a few out there for just stock replacement. Easiest to source would be the Monroe Quick-Struts, right around $100/piece for the whole assembly.
    Or the prices from @Roman at Toyota of Cool Springs are much better and they'll give you a forum discount they list $112/piece for the shocks, $154/piece for the springs and $68/piece for the mounts.
    Roman likes this.
  3. Jul 26, 2018 at 11:40 AM
    Casper421
    In the woods
    06 DC
    You can replace the shocks with bilstein 4600’s or 5100’s without replacing the springs. You can always rent a spring compressor from Napa or O’reillys. Or Toytec has an Eibach coilover set preassembled, What do you mean by upper components? The top hat and bolts or uca’s?
  4. Jul 26, 2018 at 11:47 AM
    jpcolorado
    I meant mounts. I couldn’t think of the word.
    RE: Monroe Quick Struts, are they good quality? I saw a couple articles where they wore out quickly. Maybe a good question is how long do the last with normal driving?
  5. Jul 26, 2018 at 11:58 AM
    Somemedic
    Somemedic New Member
    Mark
    2000 SR5 AC Cab/ 2010 Dbbl Cab Long Bed
    Yak racks Awning LED dash LED headlights / fog lights Hellwig Helper springs KC HD springs Bed slide out Sony AX100 w/ cam SOS Big Brake front kit Rancho 9000 front / rear
    Momma works ar Advance Auto so the discounted parts are a pretty big draw.
    Pulled the trigger on the Rancho QuickLifts for the fronts. Already installed the 9000s out back with new heavy duty spring packs from Kansas city spring.
    Her discount took $90 off of 225 x2.
