2005 double cab 4wd towing capacity
Discussion in '1st Gen Tundras (2000-2006)' started by stevechumo, Nov 16, 2019.
  1. Nov 16, 2019 at 4:21 PM
    stevechumo
    stevechumo [OP] New Member
    I have a 2005 double cab 4wd. I couldn't find any credible info on its towing capacity. Some info that I found is 4700 lbs. What the heck! The 2000 4runner already has 5000 lbs capacity. And even Tundra access cab RWD even has the capacity in 6500 lbs. I remember a long time ago that I saw a source posted that the double cab 4wd has 6700 lbs. Can you point some accurate info on this? I need to be convinced, please. :)
  2. Nov 16, 2019 at 4:54 PM
    BubbaW
    BubbaW Been Real
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Have you checked your Owners Manual ?
    The below is about my 2004.
  3. Nov 16, 2019 at 5:14 PM
    02goes
    02goes New Member
    2002 Tundra Limited 4X4
  4. Nov 16, 2019 at 5:22 PM
    Professional Hand Model
    Hand Protectors
    Turd gen can tow a space shuttle, but our 1st Gen payload capacity is higher. :yes:
    SprinterAE86 and lsaami like this.
  5. Nov 17, 2019 at 1:36 AM
    stevechumo
    Thanks everyone for your inputs. Mine is SR5 2UZFE with Bilstein shocks. It also has a large oil cooler under the front bumper. Does it mean that it has a towing package?
  6. Nov 17, 2019 at 6:09 AM
    speedtre
    speedtre New Member
    Inland Northwest
    Does it have a factory hitch?
  7. Nov 17, 2019 at 12:47 PM
    stevechumo
    Yes. It does.
  8. Nov 17, 2019 at 1:12 PM
    speedtre
    speedtre New Member
    Inland Northwest
    Then I'd say it's safe to say it has the full tow package.
  9. Nov 17, 2019 at 1:39 PM
    BubbaW
    BubbaW Been Real
    Bubba
    Where Eagles Nest
    T150 Lover
    If you create an account @ Toyota, with the VIN you can look at your actual specs for that veh.
    https://www.toyota.com/owners/register
    The below pic is pg 2 of my Veh Spec regarding Tow Pkg.
    speedtre likes this.
  10. Nov 18, 2019 at 12:05 AM
    stevechumo
    Wow! Lots of good info. My Tundra has all of the above, so I feel confident keep towing my boat.
  11. Nov 18, 2019 at 2:28 AM
    BestGen
    BestGen Free Kyle!
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    According to the chart I can pull 7300 pounds! Sweet! I thought it was 6500! :yes:
  12. Nov 18, 2019 at 2:55 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Oh, the things I pulled and the payload that I it. The '05 DC is an ox.
  13. Nov 18, 2019 at 4:19 AM
    Hand Protectors
    You can pull it, but can you stop it?
    I don’t like towing anymore than 4500lbs., basically the same weight as our trucks, in the 2002 due to the stopping factor. She can grunt and tow/haul nicely but braking with over 4500lbs. becomes scary.
    BestGen[QUOTED] likes this.
  14. Nov 18, 2019 at 4:40 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Depending on the state, most require trailer brakes above a certain weight. PA for example requires them on anything capable of carrying 3,000lbs or over.
  15. Nov 18, 2019 at 6:43 AM
    BestGen
    BestGen Free Kyle!
    Paul
    I sure hope so! I have the factory tow pkg, a brake controller, and the later years came with bigger brakes. All I'm towing now is a sandrail which weighs ~1600lbs. But it's good to know I can tow a lot more if needed. :thumbsup:
  16. Nov 18, 2019 at 6:51 AM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    My Bay Boat pushes 5000 fully loaded. Even with a bad brake actuator I had no problems towing and stopping. I do notice some difference stopping once I fixed the brakes.
  17. Nov 18, 2019 at 7:06 AM
    Hand Protectors
    This is the 1st Gen Section.
    BestGen likes this.
  18. Nov 18, 2019 at 11:49 PM
    stevechumo
    I tow my boat and trailer, which I estimate would be in the 5500 lbs or more. The rear dips down about 2". It's time for helper leaf springs or air bags.
  19. Nov 19, 2019 at 3:17 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Sorry, I will quit posting here. I was just replying to braking post
  20. Nov 19, 2019 at 4:06 AM
    Hand Protectors
    We thank you. It gets confusing when the specs are different between the Gens. Someone might read your comment and think ‘1st Gen’.
    Comment here all you want.
  21. Nov 19, 2019 at 7:10 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Note I never mentioned capacity
