2004 VSC brake fluid flush
Discussion in '1st Gen Tundras (2000-2006)' started by bron-yr-aur, Jul 27, 2023.
  1. Jul 27, 2023 at 11:47 AM
    bron-yr-aur
    bron-yr-aur [OP] New Member
    Ché Calvo
    Windber, PA
    2004 DC 4x4/Tow pckg
    Mods: zip-tied PS line and tire shine
    Hi guys,
    Yes I have the dreaded VSC on my 2004 4x4 DC. New to me, so I’d like to start out fresh on everything that I can. Especially with this horrific master cylinder. A quick search here yielded nothing for me, so…
    Any thoughts on a brake fluid flush? The sticker on the MC says things are under high pressure, and I know absolutely nothing about this system. So is flushing just like a typical system with a vacuum booster? Or do I need to find a shop with the machine? The pressure comment on the sticker has me scared…
    Thanks in advance for any insight.
  2. Jul 27, 2023 at 11:51 AM
    You mean VSC? Like, your setup is like these?
  3. Jul 27, 2023 at 12:20 PM
    bron-yr-aur
    Ché Calvo
    Windber, PA
    Yes, thank you. I fixed it. I keep thinking “management” instead of “control”.
    shifty`[QUOTED] likes this.
  4. Jul 27, 2023 at 12:28 PM
    That's all I can contribute. I know nothing about the VSC-based systems on these trucks. I'm sure someone can hop in and help. IIRC, I think there's some extra step where you hafta bleed the VSC assembly, but ... that's about all I've got on the tip of my brain.
  5. Jul 29, 2024 at 2:23 AM
    Bed Tundy
    Bed Tundy Like changing a tire, the 1st time you're careful
    Neature Gary
    Moscow, ID
    (W) 2005 AC 4.7 4x4 with VSC, (G)2005 AC 4.7 TRD Sport RWD
    See Signature or my Photo Album
    Let me know what you did? I was planning on just slowly pulling the old from the reservoir and circulating fresh fluid through it over time unless I could find a definitive method.
  6. Aug 19, 2024 at 11:31 PM
    Bed Tundy
    Neature Gary
    Moscow, ID
    Ha, thought I had found the thread I needed until I ran across my own comment. VSC owners combine our knowledge
  7. Aug 19, 2024 at 11:41 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    2” Lift, Bilstein 5100’s and 885’s second notch, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags w/Daystar Cradles. Spider Trax 1.25” Wheel Spacers, 4Runner Pro Wheels, Falken AT3W 285/75r17 (34x11).
    I just have the girlfriend press the brake while I open the bleeders at the wheels. The electric motor pumps new fluid through instantly.
    Easiest brake bleeding I’ve ever done. Unless we’re not supposed to do that?
    I’ve done it several times now and it works in seconds. My electric master booster thing has 350k on it.
    Bed Tundy likes this.
  8. Aug 20, 2024 at 12:29 AM
    Bed Tundy
    Neature Gary
    Moscow, ID
    That’s excellent! Probably the first time ever these brake units are easier to work on than standard vacuum boosters. Thank you. I plan on using Bosch 5.1 brake fluid. Any thoughts on that? Without a LSPV, or whatever the acronym is for the rear brake fluid proportioning valve is, what are the steps for us to run a complete system bleed? same as usual?
    Do you have the stock brake fluid cap and can you post a picture of the top and inside? I’ll post mine tomorrow but from what I’m seeing online mine is weird.
