2004 limited doublecab iforce JBL radio harness Saturday headbanger
Discussion in '1st Gen Tundras (2000-2006)' started by Jblhatesme, Mar 11, 2023.
  1. Mar 11, 2023 at 11:08 AM
    Jblhatesme
    Jblhatesme [OP] New Member
    2004 iforce limited
    I have a 2004 limited double cab with a jbl sound system. Bought a JVC head unit. The truck has 2 2pin connectors.Ive tried and bought 2 different wiring harnesses but both have been wrong. i can find a wiring harness for the power, but not the speakers/ Can anyone help me with this. I could really use a wiring diagram. I could run wires back to each speaker but id rather not. I was also wanting to know which wires were for the steering wheel control. i bought a maestro i was going to try to use for that.
  2. Mar 11, 2023 at 12:27 PM
    weadjust
    weadjust New Member
    Tupelo, MS
    2006 Tundra Limited DC
  3. Mar 11, 2023 at 12:31 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Do you mean 2 20 pin connectors, which is what JBl radio systems have.
    Wiring harnesses can be downloaded via this link.
    Ultimate TUNDRA Wiring Diagrams Collection | Toyota Tundra Forum (tundras.com)
    Your amp should be on back wall behind rear seats. The cable goes from radio to amp, then to speakers. Crutchfield can fix you up on cables.
    As for steering wheel controls, you should have a 12 pin connector at radio if you have steering wheel controls presently.
    FrenchToasty likes this.
  4. Mar 11, 2023 at 1:36 PM
    Jblhatesme
    2004 iforce limited
    Ok. My brain wasnt working. I was thinking that the bypass connector needed to connected at the head unit. Makes way more sense now. Unplugged the connectors at amp. connected 70-8117 at the output harness of the amp and back up to where the head unit will be great. Im not quite sure what all the other wires besides the common speaker inputs are. ill look for the 12 pin connector. i have this idatalink maestro im going to try to use.
  5. Mar 11, 2023 at 3:19 PM
    Taken from the general info thread, maybe it helps - the 1st link outlines amp locations, 2nd link covers a lot of the harnesses and how to attach them:
    • Before you install an aftermarket head unit, you need to identify whether your truck has the external amplifier, because you'll need to bypass it if it's there, else fade/balance won't work, or you just won't get sound! Read this thread for more info on the factory amp and where to find it if you have one, and what you need to do to install an aftermarket stereo. There are ways to retain the factory amp if you really want to, but ... just read that thread and its replies. To see what adapters you need (if you have an amp) check this post. To see what aftermarket radio others on here are running, read this thread. DISCLAIMER: Confirm fitment of any part numbers provided here by going to Crutchfield's or Metra's website before you commit to buying!
    Test fade/balance after installing the iDatalink Maestro. At least two of the keep-your-amp kits I know of are unable to keep fade/balance. The JBL amp installed in these trucks is inferior to a lot of the integrated amplifiers in quality modern head units, I really question why anyone pays the extra money to keep them.
  6. Mar 11, 2023 at 5:33 PM
    Jblhatesme
    2004 iforce limited
    Ok. got the stereo installed. frenched in a microphone. added the xm/sirius satellite interface. Flashed the steering wheel control. tapped into the wiring harness for that. laced it all in nicely. Had a hard as hell time as far as getting the dash back on(the fit is super tight). After all that.... I forgot to plug in the antenna to the back of theunit. :annoyed:. Took it back off, now its all good!! Thanks for the help guys.
    shifty` likes this.
