2004 Dbl Cab backup camera
Discussion in '1st Gen Tundras (2000-2006)' started by Pwhipple22, Apr 25, 2019.
  1. Apr 25, 2019 at 10:18 PM
    Pwhipple22
    Pwhipple22 [OP] New Member
    Any recommendations for a backup camera on a 1st Gen Tundra?
    OR18TRD and Y0TA PR0 like this.
  2. Apr 25, 2019 at 11:41 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    WELCOME!
  3. Apr 26, 2019 at 4:02 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
  4. Apr 26, 2019 at 5:02 PM
    ScottBaiowulf
    ScottBaiowulf New Member
    2005 4.7L V8
    Esky 4.3 Inch TFT LCD Color... https://www.amazon.com/dp/B01461MDXA?ref=ppx_pop_mob_ap_share
    Universal Mount Front Rear Camera... https://www.amazon.com/dp/B004HJ9D4Y?ref=ppx_pop_mob_ap_share
    I bought this camera and screen from Amazon for ~$40 total. They were both the “runner up” in the reviews on Wirecutter. They work great and were easy to install. I ran the cables from the camera to the cab by zip tying them to the brake line. There’s a drain hole with a rubber plug under the backseat on the driver side that you can use to get the wires into the cab. The plug fits back in over the wires just fine. The screen requires a 12v power source and the instructions say you should wire it into the ignition, which is not worth the trouble. For $7 at O’Reilly you can get a 12v plug for the cigarette lighter that has bare wire ends, takes two seconds to wire nut the power cables from the screen to it.
  5. Apr 26, 2019 at 5:35 PM
    NMTundra
    NMTundra New Member
